cam belt, timing belt ?
Danny Cawsey May 6, 2010
  1. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Right i had a look under my car the other day while it was up on the ramps i noticed that the belt located on the passenger side of the engine looks brittle, am i right in saying this is the timing belt as im sure the cams are run by a chain on the other side of the block.
    is this the belt that causes major holes in your pocked when they snap?
    and any idea of a price to have a new one fitted?
    cheers in advance .
  2. <tuffty/>
    21,242
    3,879
    ermm... belt on the passenger side???
  3. Danny Cawsey
    Danny Cawsey Cawsey
    516
    hahah sorry i ment drivers side my mistake
  4. rossbrownlee
    rossbrownlee Ross_S4
    719
    The cam / timing belt is on the drivers side pal. Not sure if it is even visible from below without removing covers.
    The auxiliary belt has grooves runing along its length. Look at the engine from above, the timing belt is under the black plastic cover on the end of the engine block. The auxiliary belt (alternator / power steering pump / aircon if applicable) is visible by looking to the left of your intake manifold where you will see the belt on your alternator pulley.
    You are half right though, one camshaft is driven by your toothed (timing) belt, this shaft then drives the other camshaft via a chain at the opposite end.
  5. <tuffty/>
    21,242
    3,879
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    15 mm dude. Deffo a 15.
