CAM BELT KIT AND WATER PUMP
Discussion in 'A3/S3/Sportback (8P Chassis)' started by tdi-man, Aug 7, 2011.
  1. tdi-man
    tdi-man Well-Known Member
    Jul 27, 2009
    1,798
    64
    MY WATER PUMP AS TINY LEAK so getting it done soon which is the best to get genuine or none genuine
    also shoukld i get pump with plastic fins or metal ?
    same as the cam belt kit does it matter if genuine or none genuine ?
    thanks
  2. Advert Guest Advertisement
  3. trev m
    trev m Member
    Nov 1, 2009
    35
  4. tdi-man
    Jul 27, 2009
    1,798
    64
    Yes used them before fir the bits but have a small leak running
    Down the back of the block so may get a genuine
    Pump
  5. TimG
    TimG Active Member
    Feb 21, 2004
    942
    45
    General consensus is replace the plastic impeller pump with a metal one to avoid future breakages.
    Most indi's advise that replica parts are made to OEM quality anyway so I wouldnt worry too much about OEM parts. I never have and touch wood, never had am issue.
  6. ryanstewart9
    ryanstewart9 Member
    Sep 5, 2009
    509
    Not sure if it's the case now, but I remember when I changed the water pump in my mk4 Golf, VW only supplied pumps with plastic fins & GSF supplied pumps with metal or plastic fins.
