What's the general concensus of opinion in the amount of damage that may have been done to my engine (1.8T) due to cam belt failure?
Small amount of belt noise from the engine, originally I thought it was the aux belt, either slipping or the belt tensioner vibrating. In the end it turns out to be the water pump seizing.
Drive out of work in the evening and 400 m down the road the noise becomes more severe and I realise it's a problem. Limp back to the office, ( so I drive the car 400 m with the problem) and switch off. Now at this point the belt has not failed, the engine is running normally, albeit with a very disturbing belt/squealing noise. Lift the bonnet and I can see that coolant has been sprayed around the bay, with rubber shards in the water.
RAC called out to tow me home, guys asks me to start the engine. It starts normally with more belt/squealing noise. Shut down after 20 seconds.
Towed home and because of the layout of my drive I have to start her up to get on the drive. Turn the key, she cranks but does not start, try again still does not start. In total cranked for around 5~8 seconds.
Reading around on similar problems, it's almost certain that the water pump has seized and the 400 m driving (at very low speed) and subsequent start up has shredded the teeth off the cam belt, but just about maintained some sort of structural integrity to keep the timing correct.
Trying to crank the engine over after being towed has caused the belt to slip or fail completely.
So what is the likely damage to values from trying to start but failing???
It will be looked at by an Audi specialist for a water pump and cam belt change in a few days, when I will know info, but before then any ideas?
