Cam belt change time
mikerd4 Jan 18, 2007
  1. mikerd4
    mikerd4 Member
    170
    Right I am ringing around to get prices to change the cam belt on my S3 as its due a changing.
    Firstly prices vary wildly! but thats not wht I am after
    Ive decided to price the bits on vag parts but Im not sure exactly what I need and they dont do waterpumps either!
    I know I need the belt obviously, but they list two types of tensioner and a damper??
  2. S2Avant
    S2Avant Member
    80
    Get your engine code and ring VAGparts, Martyn is very good.
  3. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Try GSF http://www.gsfcarparts.com/ I got my belt kit (belt, tensioner and idler) for about 70 quid, also got waterpump from there for about 25 quid. They also do G12 Coolant for 5 quid a bottle, you'll need 2.
  4. simch
    simch Active Member
    2,028
    I would use GSF again.......great service and good prices all OEM equivalent, some even have identical casting marks, just in diff boxes!
    Change everything........all rollers, belt, tensioners, ( ask for the kit with the the hydraulic tensioner thingy) waterpum, get the metal impeller one if you can (brass). It was about 150 quid for it all IIRC, but just not worth all the labour and not change things.
