Cam belt change service info (TDI)
PH1 Aug 16, 2007
  1. PH1
    PH1 New Member
    Hello,
    Can any one help me I'm about about to change the cam belt on my wifes A3 TDI 2.0 Sport Model MY 03. I have picked up the kit and the locking tools and am a little confused about setting up the tensioner. Does any one have a any service info they could send me on how to install it.
    Paul
  2. S3 Jock
    S3 Jock Member
    84
    what don't you understand about the tensioner? is it one of the indicator types - ie a pointer you line up with the mark to set correct tension?
  3. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Normally you just bolt it up, then use an allen key to move it until you can get the belt on, then you release it to tension the belt up.
