StuartC
I have '94 Cabriolet Auto 2.8E with power roof. When I start the car, the 'roof' icon flashes in the instrument panel and will not stop unless I disengage the handle that opens the roof and close it again.
Also when I try and open the roof, the hood lid that the roof drops into will not lift, and the roof icon flashes in the instrument panel.
I have had a company called John Austin (Independent Audi Specialist) in Colchester look at it. I had to take the car back twice, but although they are an Audi Specialist garage It seems all they did was contact an Auto Electrician who visited the garage to fix the problem. He thinks that I need an ECU.
This all started after the car went in for a service and had a new off-side rear light bulb fitted!
The roof was repaired last year with the same problem and had a new wiring loom fitted (how much!!!) to the off-side, so I am feeling a bit peeed off with the garage and their lack of concern.
Anybody got any ideas?
There is an cheap ECU ( PART NUMBER 8G0959723E ) available, but Im not sure if this is the right part, or, will in fact, fix the problem.
Stuart
Stuart
