Cable under drivers seat
PDA3 Jun 6, 2014
  1. PDA3
    PDA3 Member
    65
    Hi, while searching for a macdonalds chip that fell in beneath the drivers seat, I noticed a chunky insulated electrical cable coming up through the floor and directly into the underside of the drivers seat. Can anyone help me understand what this is for?
    For a minute I thought it could be an additional sub woofer under the seat, but having b&o I think the only sub is in the boot. I don't have heated seats.
  2. bobinder
    bobinder Active Member
    174
    30
    Do you have electrically adjusting seats?
  3. PDA3
    PDA3 Member
    65
    No, just an s-line with b&o, tech pack, etc, no electric seats
  4. monopole
    monopole Well-Known Member
    1,154
    469
    heated seats?
  5. PDA3
    PDA3 Member
    65
    Nope... Unless there is electric lumbar support (think that's standard but never used it) but seems to be a thick cable just for that.
  6. Joetidman
    Joetidman Well-Known Member
    1,009
    515
    Sorry you were eating a Macdonalds in your car ?!?!
  7. PDA3
    PDA3 Member
    65
    I know can you believe it! I managed to last over a month tho!
  8. steverobertsbbc
    steverobertsbbc Active Member
    370
    177
    43
    It's there as an anti-depreciation device for the rest of us. If you start having thoughts about lowering the suspension 50mm, wiring your foglights to be permanently on or adding a subwoofer the size of Wales into the boot, it automatically sends 10KV up through your arse and re-educates you. :p
    Ceho, cemerson and snakehips like this.
  9. monopole
    1,154
    469
    also need a seatbelt sensor, so perhaps the electric lumbar + seatbelt = the loom you describe?
  10. Joetidman
    1,009
    515
    Only water allowed in mine (at most) although I admit as a result I haven't seen the wire under my seat ;)
  11. andywil13
    andywil13 Active Member
    380
    68
    It will be the airbag
  12. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    If no heated or electric seats then will be the cables for the airbag and possibly seat occupancy sensor (for seatbelt warning light)
    Electric lumbar support is not standard in most countries but is a build option.
    John.
    P.S. I bet that even after a month, that McDonalds fry didn't have any mould on it and looks as new as ever. That statement sums up its nutritional value if even mould won't grow on it.....
  13. PDA3
    PDA3 Member
    65
    John, the fry was removed literally on impact, don't want you thinking I would dare leave it there for a month! ;)
  14. PDA3
    PDA3 Member
    65
    Thanks all, so seatbelt and airbag control. My mind can rest!
  15. JohnM100
    951
    394
    Fair enough. Glad to hear of the prompt recovery of the fry.
    I see a cluster of responses within seconds of each other with a consensus on airbag and seat occupancy sensor.
  16. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,522
    1,145
    There are airbags in the seat? What are they for, to fire you through the windscreen in the event of an impact?
    I doubt it'll be for seatbelt sensor on the drivers seat... it's pretty safe to assume that there is a driver if the car is moving!
  17. cemerson
    4,522
    1,145
    Lumbar Support seems the most likely explanation to me
  18. PDA3
    PDA3 Member
    65
    I just popped out the car and can't even find the lumbar support button, so not sure if it's electric or not....didn't spec it as an extra tho.
  19. cemerson
    4,522
    1,145
    It's standard with leather seats I think (or at least it requires you to spec it... could be wrong though). It's a round, 4 way control if you have it, right down the side of the seat at the front.
  20. The Challinor
    The Challinor Well-Known Member Audi S3
    4,322
    1,101
    So electric lumbar is standard with leather seats then? Wasn't aware of that
  21. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,759
    Seatbelt buckle switch
    Torso airbags (pyrotechnic)
    Speaking of pyrotechnics - have you noticed the (yellow label) pyrotechnics at the bottom of the bonnet hinges :)
    edit:
    Seatbelt pre tensioner in this car is in the inertia reel, not buckle.
  22. cemerson
    4,522
    1,145
    I could be wrong on that!
  23. veeeight
    6,849
    4,759
    No, lumbar is not standard with standard or sports seats
    Electric lumbar is standard with SS seats though
  24. cemerson
    4,522
    1,145
    Ah no, it's the storage and luggage pack I'm thinking of!
  25. The Challinor
    4,322
    1,101
    Thought so, just checked brochure.
    Full electric seats in the 8l S3 as standard, no such love for 8P or 8V
  26. cemerson
    4,522
    1,145
    I'm kind of glad about that (from an A3 perspective). Electric seats would be useful if they had a memory function with some buttons, but instead it saves it to the key which is useless to me! Other than the memory function, electric seats aren't actually very useful, they are just slower...
  27. Flibble
    Flibble Active Member Team Estoril
    544
    142
    43
    They're side impact airbags; they fire out of the side bolsters, rather than out of the seat cushion. ;)
  28. cemerson
    4,522
    1,145
    Oh, thought those would come from the side of the car! Guess that's what the cable is for then. The seatbelt stuff would be in the seatbelt socket (unsurprisingly), not the seat!
  29. The Challinor
    4,322
    1,101
    Your keyless I take it haha
  30. cemerson
    4,522
    1,145
    Yes, but that doesn't make a difference to that functionality!
  31. AJB
    AJB Active Member
    175
    43
    Yes, but the seatbelt socket is normally attached to the seat so that it goes backwards and forwards with the seat and stays in the right place. So, the wire to the switch in the socket will go up into the seat, along with the side airbag wiring.
