Cable routing in an 8P
gg9485 May 11, 2007
  1. gg9485
    gg9485 Member
    41
    i will soon be installing my car pc into my car aswel as an upgraded sound system which will include a sub in the boot, I need to run a 4gauge power wire from the battery to the boot, anyone know if there are a ny holes in the bulkhead I can pass tis through? or will I have to drill my own.
    I also need to run various cables from the dash to the boot, including a VGA cable and a serial cable, again any idea on the best place to route these cables?
    by the way my car is a 2004 sportback manual if that makes a difference
    thanks
    greg
  2. SamDude
    SamDude Active Member
    2,102
    Have a look under the door/carpet trim that runs on each side. It may be tricky, but you can run the power cable down one side and the VGA/usb/serial/audio down the other side (just to keep the power away from other lines) .
    *Works for my Golf, not tried in my A3
  3. Boydie
    Boydie Guest
    my 0 guage cable is under the car and fed up through a bung in the boot
    very neat and tidy job!
  4. gg9485
    gg9485 Member
    41
    Thanks guys, Think i might run the power cable under the car, keeps it away from everything else, I neglected to mention I will be running new speaker cable aswel.
    Boydie did you drill your own hole to pass the cable through or was there one ther you could utilise?
  5. Boydie
    Boydie Guest
    a bung came with the wiring kit so a hole had to be drill for it - its water tight so it grand
    just go down to b&q and get a decent grommit or something similar
