Cabby door card removal - HELP !!!
markyzs180 Jun 18, 2009
  1. markyzs180
    markyzs180 Member
    543
    Hi there,
    After having trouble closing the drivers window this morning i thought i'd pop the door card off to have a look but as you can guess from the title I failed miserably!!! :(
    I have removed the trim and the four screws behind it and the one at the very bottom of the card but pulling it away from the door I'm finding that the centre section where the handle/rest and window switches are is refusing to budge, am I missing some elusive screws hidden behind some trim?
    Any advice gratefully received and I'll also take pics while i'm doing it and post up a 'how to' guide!!
    thanks in advance :icon_thumright:
  2. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    Hey Mark,
    I'm not taken mine off but I'm sure I remember reading that there is one/two behind the handle that you pull the door closed with (not the handle to open the door)
    Paul
  3. markyzs180
    markyzs180 Member
    543
    Cheers Paul, I'm sure there is but just can;t seem to see where the pesky things might be!!
  4. maxvw
    maxvw Member
    30
    take out the window switches and theres a torx screw in there
  5. markyzs180
    markyzs180 Member
    543
    Thanks bud, I take it they just prise out?
  6. maxvw
    maxvw Member
    30
    yes,from the front i think.mine comes out if i put my fimgers under the switch as if to send both windows up and apply a bit more lift!!!
  7. markyzs180
    markyzs180 Member
    543
    cheers max :icon_thumright:
  8. markyzs180
    markyzs180 Member
    543
    Right then panel off!! Bad news is.......regulator wire has been chewed up by the mechanism, got one from the dealers and am about to attempt to fit!!!
