Cab radio signal...
Louis Cronin May 11, 2011
  1. Louis Cronin
    Louis Cronin Member
    67
    Hello people,
    I hear this is a common problem with cabs, the wire which runs to the boot throught the right side tubing stretches and breaks.
    Has anyone fixed theirs?
  2. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    My radio reception is the same, sometimes it works other times its shocking. I have been meaning to sort it out but keep putting it off.
  3. Louis Cronin
    Louis Cronin Member
    67
    I've tried hitting it but that didnt work. Im fresh out of ideas now... anyone?
  4. s4matt
    s4matt New Member
    Mine was doing the same, opening and shutting the boot made it worse!. The cable from the signal amplifier runs in the loom on the left hand side of the boot - this is usually where the cable work hardens and breaks. Managed to fix mine by buying a replacent cable from my local audio shop and spliced it on to the existing cable on the car body side of the loom. Works fine now and is easy to replace if it fails again.
  5. hades-
    9,481
    646
    as above you can get the repair wire from audi
    you can cut and join but iv always replaced the full wire
    hours job quite easy
  6. Gabsy1972
    Gabsy1972 New Member
    15
    does anyone have a pictures of how, and where the wire is? i would really appreciate it. Carl
  7. rjm180
    rjm180 Active Member
    581
    34
    I would greatly appreciate a few pics too to give me a bit of a start and a couple of pointers to do this fix aswell.
    If anyone can, please.
  8. hades-
    9,481
    646
    just take the boot liner off look on your left the amp is there and its the wire with the blue plug
    follow where it goes its realy simple
  9. rjm180
    581
    34
    Bez, thanks for reply, is the boot liner in the boot lid or is it some trim around the boot floor or sides. Sorry if question sounds stupid.
  10. hades-
    9,481
    646
    sorry yeah its in the boot lid
    if you remove that take a pic and ill point out the wire for you
  11. rjm180
    581
    34
    Ok mate, will do.
  12. mjsulliva
    mjsulliva New Member
    19
    Hi, I've got this problem too. Couple of numpty questions, is it Cab specific or does it affect all B6's? I've got a saloon, and my radio reception has suddenly gone.
    Also, how the hell do you remove the boot lid liner? I gave it a good yank and thought I was going to bust it (so left it)
    cheers,
  13. hades-
    9,481
    646
    on the b6 its not in the boot its in the back window trim
    search it on google theres a few how to's
  14. carlos19664
    carlos19664 Member
    60
    hi mate did you get Picture taken of boot problem? need to do mine now got the same problem!
    thanks
  15. rjm180
    581
    34
    I haven't had any time to look at it yet, sorry. Will prob be a while before i get chance to.
  16. rjm180
    581
    34
    Bez, were you referring to saloon and avants only or do you know if the cab is the same.
  17. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    59
    I've found a few links with google searches, but nothing that great - if people find any really good guides (for the saloon in my case), then please feel free to share.
    Do you really just pull the headlining down above the back window?
  18. Gaz!
    Gaz! Member
    161
    14
    I have this problem aswell, no radio reception at all. Ive had the boot lid liner off and cant see any thing in there. Does anyone know exactly where I need to be looking on a b6 saloon?
  19. BahnStormer77
    2,773
    59
    I think it's inside the cabin, in the headliniing, above the back window..... but I'm not tryign to pull that stuff off until I know wha ti'll need to put it all back together again!
  20. Gaz!
    Gaz! Member
    161
    14
  21. BahnStormer77
    2,773
    59
  22. BahnStormer77
    2,773
    59
    Anybody know if you can tell which part you'll need BEFORE you pull the headlining apart?
    I can see literally dozens of part numbers in VAGcat, mostly starting with: 8E5035225.
    Also: since my RNS-E was retro-fitted, should I be trying to match the aerial booster to one of the "for systems with navigation" boosters or just match the original?
    I'm guessing there's not that much difference, since they only seem to specify a different one for the Avant, not the Sedan, but there's also a naggging feeling of whether it was the upgrade that caused the booster to fail in the first place, so I'd rather make sure I got the right one.
  23. Gaz!
    Gaz! Member
    161
    14
    I have wipped the head linning off and found my amplifier and the reason for failure.
    It has a crack running along it that I can only assume has happend through temperture fluctuations. The part number is 8E5 035 225 D.
    I have done some research and found it to be a common fault.
    Found here in this post, Anyone know why the antenna booster cracks and breaks? Been searching and it's common.. - AudiWorld Forums I have exactly the same problem and have found lots of others have the same.
    I have also found that the part number is supercedded to 8E5 035 225 S, this is beefed up and shouldnt fail.
    The cost from Audi, £140....... for a piece of printed circuit board.
  24. reggieroo
    reggieroo Member
    259
    We have the same problem with an A4 Cab, no radio at all.
  25. carlos19664
    carlos19664 Member
    60
    Have a quick Chat with NHN he knows a little about this problem fixed my A4 CAB few days ago I was having the same problem
  26. NHN
    29,331
    1,716
    I will check those pics Carl, for cracks, didnt notice any mate huh.
  27. carlos19664
    carlos19664 Member
    60
    hi mate.... happy with it as it stands all good still waiting for steering wheel? aqny joy on ampire DVB-T....do I need anything else to go with it?
  28. mzwolfie
    mzwolfie New Member
    I have a 2005 Audi A4 cab and live in New Jersey, USA. I need help finding an audio technician who is familiar with doing this repair. I took it to one shop where we accessed the module with the three wires. Even with the length of wire (previously covered by the rubber tubing) exposed, we could not find the damaged part of the wire to cut & splice in new wire. Also, the tech said the wire is a coaxial type that cannot be spliced. Is that true? I really want to do this repair myself but need some guidance. If you can help me, I would be most grateful. If not, 1) can you tell me where to find the correct replacement wire and 2) can you recommend a technician in the NJ/NY area who can do the repair? Thank you.
  29. hades-
    9,481
    646
    the wire you need is from audi as a repair wire.
    im in the UK so cant point you to a technician.
    but i have never cut and spliced i use the full repair wire and run it back upfront to the head unit
  30. mzwolfie
    mzwolfie New Member
    Thanks for te quick reply. Last (I think :sm4:) question: Can you point me to a wiring diagram so I can try and replace the wire myself? One of your posts said it is a fairly simple job and I am kinda handy.
  31. NHN
    29,331
    1,716
    Nah you dont get coaxial repair wires, you get coax cables you can cut & splice, but you have 2 options, find the damage & repair via soldering/temp twist & tape or run new coaxial through with correct connectors on ends.
  32. atex949
    atex949 New Member
    13
    Fixed my cab cable at the point where it runs between the boot lid and the main body. Don't worry about all that coax rubbish, we're not listening to faint radio signal on alpha centauri. I just soldered/spliced a piece of wire in across the central core and then wrapped in a pience of insulating tape then twisted the outer shielding mess together but this leaves a shield gap. So I wrapped the whole repaired area in tin foli and wrapped in insulating it all together to make a neat job and stop it falling apart. Works fine. btw the A4 cab signal is notorious for dropping in and out anyway but this fix improves things as it keep the cable length optimum. I did think about extending the cable by adding an extra pice of wire at the repair point and running it across the boot lid or in the boot perpenidcualr to the exisiting cable to maximise reception. Will try it one day to see if it makes a difference and will repost.
