C6 alloys on a C7?
rsb2486 May 28, 2012
  1. rsb2486
    rsb2486 New Member
    26
    Ive just ordered a new shape A6 sline with the stadard 18" alloys. i couldnt get the 19" as i needed the car as soon as(order times with 19" were too long for me).. question is will the current 19" le mans style alloys or any other 19" audi alloys fit the newer shape A6?..anyone tried?
    I read on a online forum somehere that its not poss to fit older C6 A6 alloys onto the new A6(C7).
    cheers!
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Well the new C7 can be specced with the 7 Arm Double spoke so I say why wouldn't it fit .. Just check the stud pattern and offset.
  3. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    I'm pretty sure the tyres are a different spec, so if you replace those, I think it'll be fine...
  4. polo classic
    polo classic New Member
    Whats the center bore on the C6? Is it 57,1 like the earlier? C7 is 66,5mm center bore
  5. BahnStormer77
    2,773
    60
    Polo's right: that's a surprise, most of the VAG wheels have been interchangable ever since the move from 4-stud to 5-stud in th eold Mk3 golfs!
    This US website says:
    [TABLE="width: 100%"]
    [TR]
    [TD]Hub centerbore:
    [/TD]
    [TD]66.5 mm
    [/TD]
    [/TR]
    [/TABLE]
  6. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    That's a pretty sweeping generalisation... design has nothing to do with fitment. The new A4 (B8) has the bigger centre bore too, but I think the C6 was still 57.1 bore so if you're after new wheels you will probably have to get them off a newer car.
    Offsets will be the other stumbling block, so check your current wheels vs whatever wheels you're after. Higher ET can be compensated for with spacers.
  7. BahnStormer77
    2,773
    60
    I think we've all got a bit complacent.... VAG went through a phase for most for the last 10 years where everything apart from the S-cars could have their wheels swapped around to a reasonable extent: all 57.1mm, mostly ET45-ish... so if they were the right size and width, they'd probably fit... sadly not any more!
  8. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    maybe for the newer cars..... but all the new stuff will fit on the older ones :)
