Bye bye waffle weave microfibre. Hello karcher wv50!
_G_ Oct 28, 2012
  1. _G_
    _G_ Active Member
    876
  2. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    You dried the whole car (body)using this!? Definitely sounds like a worthwhile investment as I'm sick of streaking drying towels whenever I'm drying. :keule:
    I've been told once before that squeegees can damage paintwork however so wouldn't this be doing the same thing?
  3. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    anything you drag across the paintwork can damage it
  4. slade777
    slade777 Member
    763
    I have one of these for the shower. I would consider it on the glass but definitely not the car!!! Scratch hell.
  5. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    as above, even if you have washed the car body, using anything like that will scratch the body work. I used one of those rubber car squeegee's ONCE and it took hours with a DA polisher to get the scratches out.
  6. _G_
    _G_ Active Member
    876
    nah i think scratch heaven is an aqua blade... its way more thicker and designed to be pressed close to the surface to capture the water and help shift it... i used this after claying... and i used it with very light pressure... i found that using the waffle weave was actually worse because I throw this 50cm x 50cm sheet on the car and just drag it and move it without seeing what I am doing beneathe it.. so its worked for me and I used it carefully but I will keep an eye out for unsightly scratches when I get the flood lights out tonight to DA it.
