buying/coding new immobiliser transponder
fARQUARE Aug 8, 2010
  1. fARQUARE
    fARQUARE Member
    228
    Okay, i got rid of my b5 avant 1.8t sport recently and replaced it with a b5 avant 1.9 tdi, i'm slowly getting the tdi how i want it and so far i've:
    -removed and cleaned the inlet manifold and egr valve
    -replaced maf
    -replaced all vacumm lines
    -new n75
    -remapped
    -new wings
    -added my old "16 avant sport alloys
    it's now running fine, however i used to have keyless entry on the sport, it was a votex unit that i bought off a member on here. I tried to swich this on to the new car but the
    pins on the pump were different so no joy.
    Having read up on the '96 central locking and knowing the limitaions of the system i;ve decided the best thing to do is buy the tried and trusted rightclick remote entry system off the bay.
    Thing is i only got 1 key with the car so i'd like to not butcher that key for its transponder chip, can you but these transponders, if so any good known sources?
    Then i guess there is a variation on the usual procedure to code the new transponder and plant it somewher in the rightclick keyfob?
    Tried searching but the new search options are not the best.
    Thanks in advance
  2. griswold
    griswold Member
    350
  3. fARQUARE
    fARQUARE Member
    228
    I saw that link on ebay last night - it says the earliest is 98 on though, would it work in a 96?
    I have a cheapie ebay lead, is it the same lead for vag tacho or do i need to get a new one?
    cheers
  4. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    14
    that ebay chip is for immo 2
    if yours has seperate immo box then you need a 'megamos 13' transponder chip
    try hickley valtone if you cant get them on ebay
    vag com and vag tacho are completly different you will need new cable and software
  5. fARQUARE
    fARQUARE Member
    228
    Hey, thanks for the heads up. Stupid question but how would i check to see if there's a seperate immobiliser box?
    I guess i should just take the part number from the pump and that would be a start.
  6. aragorn
    18,443
    847
    What year is it? If its a '96 it'll have the seperate box.
  7. fARQUARE
    fARQUARE Member
    228
    Yes it's a '96 on an 'n' plate. Is this the seperate box under the rear seat?
    Can anybody see a flaw in my plan or is there an easier (cheaper) way to achieve the same result?
    So i'm planning on:
    -buying and rightclick system
    -getting a megamos 13 blank transponder
    -getting the haa key blanks cut at a local place
    -buy vag tacho to get the skc
    -code new rightclick key with vag-com using skc code
    I assume you need the full version of vag-com to code the key, in which case i'll need to find someone who has the full version to do the coding part.
    thanks folks
  8. griswold
    griswold Member
    350
    You do need the full version of vag-com to code a key
    If you use vag tacho to get your pin then you can code your new key with vag tacho too i did my A6 with it
    I couldn't find anyone local who could cut a key so i got one off ebay, you just send them a digital photo so they can match the profile
  9. aragorn
    18,443
    847
    The immo box is up under the dashboard next to the steering column.
    Post your location to see if anyone near you has the kit.
  10. fARQUARE
    fARQUARE Member
    228
    no worries, i'll let you know how i get on
  11. fARQUARE
    fARQUARE Member
    228
    Just as a side note, i was looking through the options of the car and found the following:
    8QL = Key for locking system with remote control
    could it be that i can get away with a new key with remote control? There are no IR recievers on the B pillars, this has got me a bit confused.....
  12. aragorn
    18,443
    847
    what is the part number on the central locking pump?
  13. fARQUARE
    fARQUARE Member
    228
    looks like 4ao 862 257 j
