Buying blank keys off ebay
drewbee Mar 27, 2010
  1. drewbee
    drewbee Member
    196
    Hi guys, has anyone bought a blank key with transponder off eBay and sucessfully got it working? I came across a seller with a blank key n transponder plus instructions on how to program it to your car. Is he talkin **** or is this true?
    Will second has fobs work? My plan is to buy it, get it cut at key cutters n get Audi to programme it.
    Anyone done this and is it possilble??
  2. NHN
    29,328
    1,708
    The remote side can be programmed by you possibly with a procedure but no guarantees, vagcom will do this for you no problems, but the immo system is a no no full stop, the key is 2 functions that are completely seperate from eachother, remote locking is 1 & other is immo for starting car, not linked at all, so immo has to be done by dealer or a cluster specialist, if you had your skc, aka: security key code then you could use vagcom to code, but unlikely you have this.
  3. griswold
    griswold Member
    350
    I got a key blade cut online from ebay seller ddkeyprogrammers for £7 del. for my A6
    I couldnt find anyone by me who could cut an audi key
    sent a picture of key but they match the profile to cut not the picture perfect match was reccomended by another forum member olds_kool
    None listed at moment but you could ask them?
    Very happy with them
  4. drewbee
    drewbee Member
    196
    Thanks NHN. So this is possible but needs the dealer to program. This way would still be cheaper than buying a new key from Audi. Last time they quoted me £200!!
  5. drewbee
    drewbee Member
    196
    Cheers for that. There's another company on eBay now doin the same service. Don't rem their name but they charging £10 Inc del. Not keen bout the idea they they cut from a pic but cos you've done it I might give it a try. So u just send them a pic of your key and they do the rest??
  6. Tyler Owen
    Tyler Owen Member
    78
    I did the flip key conversion when i had my Seat Leon
    I bought the Fob and key blank off the bay and took the transponder chip out of my non remote standard key and swapped it into the flip key and then got the blade cut at Timpsons, then just coded the remote locking features and it was good to go
  7. griswold
    griswold Member
    350
    Yes its just to match the profile so you get an un worn key its not cut from your picture.
    Also i didnt have to remove the key from the fob for the picture as I only had 1 key this was important i didnt damage it.
    I'm sure they will list again as the one that were listed have just sold.
    They sell 2 types of audi keys i bought the wrong one first and they emailed me about it as both keys look identical
    Got the key next day
  8. chrisash32
    chrisash32 Member
    573
    I had 2 keys cut from the same person on ebay as i have converted to B7 keys... Perfect match, cant complain at all :)
  9. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,196
    160
    Can you buy your SKC from audi?
  10. NHN
    29,328
    1,708
    No, the skc isnt seen by the dealers anymore, was changed years ago, all done over the line via germany without any codes seen by technicians, also be warned keys bought 2nd user may not work on your cars, given some cars like the 8P for example have the immo megamos 48 chips precoded with the vin & brand before going to dealer, these immo's are once only programmeable, although my B6 seemed to code with the newer style keys I got from a seller few years back, so beware.
  11. N80KRR
    N80KRR Member
    180
    So if i were to buy a key cut from ebay (£10), virgin transponder (£40). What would the next step be? I only got one key when I bought mine, and really worried about losing that. would someone with vagcom be able to code it for me? Or would I need to take a trip to the stealers?
  12. NHN
    29,328
    1,708
    If you dont have skc, then you need to goto dealers or an alternative.
  13. drewbee
    drewbee Member
    196
    i've just phoned my local audi specilist and they charge £40 plus vat for code a new chip. not bad if you ask me! goign to get mine done soon.
  14. MDA
    MDA sploorer
    87
    i bought my spare key off ebay virgin transponder blank key
    £12..
    had it cut and programed locally all in cost me £60 inc cost of key
  15. drewbee
    drewbee Member
    196
    £12 Inc transponder is cheap!! Keys with new chip I've seen go for £40. never the less, still cheaper than a new key from dealers lol
  16. defsix
    defsix Member
    181
    I just finished my key project, I bought a blank key and shell as mine was a little worn. Simple refit as i have 2 keys. Getting the Immobilser out was quite hard, a matter of gently heating the key and cutting of the plastic around it, then it just popped out, I can confirm mine was glued in . So i reglued it into the new key, straight swap for the key shank with an extra twist of the spring for superfast key flicking :D . Then came the battery section, my pcb was held in with brass pins, so i cut these and placed it into the new shell, the battery and spring will hold it in place. As for the battery holder i found that the side battery spring was located in a different place to my original so and the remove and refit, the plastic was already moulded for this. Finished. Now to unlock the car, because it took so long it didn't work, So opened with original 2nd key , put the new key in the car and started it, left it running for a minute ( to confirm i didn't break the Immoboliser ) whilst the key was in the ignition i press the unlock key then lock key. Take out the key and now everything works. total time : 20 mins
