Buying an S3 THIS WEEK! *Fingers Crossed!* But Which One?!
Ryan_W Apr 26, 2011
  1. Ryan_W
    Ryan_W Member
    336
    Afternoon all,
    Basically, I've been an viewed 4 S3's over as many days. Details of the cars are below...
    2001 Y, Silver, 66k, 330bhp, £8500
    2002 02, Black, 56k, 225bhp, £7495
    2002 02, Black, 53k, 225bhp, £7995
    2003 03, Silver, 58k, 225bhp, £7650
    Now should I go for the modded, older car, or buy a mint standard S3 and build it up (spending lots of money) as I go along? I'm really unsure what to do.
    I think I like the idea of a mint low mileage example, but I know I'll miss the power coming from a 400bhp Saab 9000. The 330bhp S3 was definitely the most fun to drive. However, when coming onto full boost, it did make a screaming noise before quieting down and holding boost (posse bearing issue?).
    I know this is a bit of a rubbish thread, but I'm really stuck and I need your help! :)
    Cheers all,
    Ryan
  2. S3 AUO
    S3 AUO Member
    201
    10
    I think the first question that you have to ask yourself, is if you want to mod the car yourself.
    Depends how much you would enjoy making it your own work or use someone else premade.
    Personally I like the black S3, a lot more then the silver ones but of course thats down to personal opinion,
    At least your looking at a BAM, and the millage of the 3 standard ones seems to be good, obviously you saw the condition and would be in the best position to decide.
    Hope this helps, however it probably didn't :D
  3. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,826
    3,479
    330bhp is where it's at. You yourself have stated it's the most fun to drive, does it have modded suspension and uprated brakes to help you make use of the power? I'd be sold on that one personally.
  4. Ryan_W
    Ryan_W Member
    336
    I do LOVE tinkering with cars, I've had quite a collection of road/track cars, ranging from 120bhp AX GTi's to my current 400bhp Saab 9000.
    But I also HATE it when they breakdown, need fettling with, when 'all' I want is the best of both worlds, performance and reliability.
    The 330bhp S3 does have a Brembo BBK and Eibach suspension, handles a treat, but my budget is pretty much maxed out at £7.5k and they guy said he'd go no lower than £8.5k...
    I'm really undecided... Surely the new cars would hold better value than the Y reg vehicle?!
    My heads in bits. If the guy with the 330bhp S3 would take £7.5k, I think I'd be silly to pass on it?...
  5. Ryan_W
    Ryan_W Member
    336
    Quick question... Would the 2001 Y plate car have a BAM or APY, AMK engine? Thinking/hoping BAM, but not too sure.
  6. karls s3
    karls s3 Member
    234
    i have a 2001 y and its a amk and its the facelift model
  7. Buzzer
    Buzzer Member
    410
    14
    Amk upto November 2001 and bam after that
    Wouldn't really matter if remapped anyway(performance wise)
  8. cabby86
    cabby86 Member
    112
    2001 on a Y would be AMK, my old S3 was a late 2001 '51' reg and that was AMK, when I was looking I went and looked at a 2002 '51' reg and that was a BAM. From the brief research I did, this is the earliest the BAM engine was available. I found the majority of BAM engined cars are '02' reg onwards. As I am sure you will have read there is very little between the two and both will re-map to approximately the same figures.
    Chris
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    The guy will have spent some serious dosh on the 330 bhp one
    So it will be money you don't have to spend...
  10. Agric04
    Agric04 Member VCDS Map User
    288
    Don't know if it will have any relevance to you but the newer BAM engines fall into a slightly higher co2 rating so will cost more to tax. It's also worth extra money if the cars has had the suspension bushes, the oem bushes deteriorate with age, even low mileage examples may suffer.
    Bought my 2001 S3 in Feb with 130k for £4k but have already spent another £4k tidying it up, remapping, polybushing, suspension plus other bits and there's still more I'd love to do. If the modded one has been done well I'd go for that, My strategy was a bit of a false economy buying a cheaper one! I'm still happy with it but would do things differently next time.
    If you have access to vcds, it's worth taking someone with you who can scan the car for fault codes.
  11. sportstractor
    sportstractor Chugger
    2,709
    35
    i would buy one with higher mileage but looked after (like mine :p) for £5500 then use the remainder tuning the hell out of it. Thing is with buying a modified car is do you know for sure it been done properly and setup to be reliable.
    Also wouldnt go for black. I wanted a black one originally but after seeing quite a few in the flesh since, I now do prefer silver. Although my favourite has to be red as it does stand out rather than just looking like a pimped A3
  12. SL11CKK
    SL11CKK Active Member
    686
    35
    if you can post the number plate. can find out what it came with originally, provided its still running the same engine.
  13. Agric04
    288
  14. Ryan_W
    Ryan_W Member
    336
    This is the spec of the 330bhp S3:
    Garret GT28RS
    Hi Flow Custom manifold
    3" Stainless downpipe
    3" Stainless inlet pipe
    Stainless Charge pipe
    Metal sports cat
    Supersprint stainless steel sports exhaust
    Braided oil and water hoses
    Genesis Injectors
    Revo Stage 3 map
    Forge FMIC
    Uprated Forge Diverter Valve
    New timing belt + Metal waterpump
    Pipercross air filter panel
    Brembo GT front brake kit
    EBC vented/drilled rear discs and pads
    SPA Boost gauge
    Poly engine mount bush
    Eibach lowered (don't know if this is shock and/or springs)
    Forge adjustable rear tiebars
    BBS CH wheels
    Bose
    Cruise Control
    Centre armrest
    6 Disc Changer
    Sony 500W mono-amp fitted in place of Bose Sub
    10" Alpine sub
    Do you think that's work £8.5k?
    Car's bodywork is exceptional but the cream and leather alcantara seats have seen better days (and they're not heated). Best way to make these look like new?!
    Ryan
  15. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Genuine BBS CH's? Surely not?
    If I had that money I'd be going for the 330bhp one. Ok, it's not been built by you, but provided there's history to support it, it's another 100bhp over stock with the brakes and handling mods to match.
  16. Ryan_W
    Ryan_W Member
    336
    Yes they're genuine BBS CH's. They have a few scuffs and I'd get them refurbished, but they still look great!
  17. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Even better then, seeing as they're not exactly cheap. Ask yourself whether or not you'd end up spending the money on mods anyway? You can sell the CH's and put it on cheap(er) rims or even stock until you get bored, and still have the power!
  18. wdbdy2000s4
    wdbdy2000s4 New Member
    with those mods you'd be silly to pass on that car. If you were to do a 28rs build with suspension/brakes/CHs/etc. you would have to pay 10k.
  19. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver quattro Audi S3
    1,749
    184
    As for the seats mate A bobble off should get rid of most of the clumps and bits, you can get them off fleBay for next to nothin, if there just dirty then check this website out
    Swissvax Alcanta Textile Cleaner For Alcantara - FREE UK Delivery
    hope this helps but definatly go for the 330bhp. :racer:
  20. Ryan_W
    Ryan_W Member
    336
    You're a ledge mate, they would both bring the interior up to a good standard.
    I've just sent the chap an email now saying that I really want the car and to see if he'll negotiate on the price... FINGERS CROSSED!
    I really want an S3 NOW!
  21. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    deffo go with the tuned one unless you want to spend big £££££ to get the mods it's got.
    I got mine standard 2 years ago for about 7G's
    i've spent £4-5 on it since. and still another £2-4 togo.
    But like youself i like to tinker with it and occasionally not do jubliee clips up properly. lol
  22. Ryan_W
    Ryan_W Member
    336
    I hear what you're saying... I can't be doing spending £8k+ on a car just after I've bought it!
    The 330bhp car does need some work though, it fluctuates slightly at high boost (after over-boost), it's got me thinking it could be anything ranging from a cheap solution of £200 for a new adjustable actuator, to a pretty expensive potential boost seepage issue from a number of gaskets (worst case, turbo of head gasket). Now I know it probably will be just a weak actuator, and a Forge jobbie with an uprated spring could solve the problem, but it's still in the back of my mind.
    It also needs its wheels refurbished which would cost me £200 at mates rates. I'd also get the front seats restored either by myself or potentially getting a professional company in to do the job.
    Only other thing noted as that the instrument cluster had a couple of faults in it (line errors in the display), which could mean getting a new unit and getting it reprogrammed?
    What do you guys think?
    Ryan
  23. superkarl
    superkarl MAN OF STEEL
    9,329
    2,334
    Why should I car be more than market value just bwcause of mods?! Since when do modifications increase the value. It's over priced, I'd go as far to say the other shouldn't be more than 7k
  24. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Because mods cost money
  25. Jason.s
    Jason.s Active Member
    2,879
    348
    Doesnt work like that though.
    People think like that which causes the high prices but in reality a car with mods would usually go for the same if not sometimes less than a standard example because with mods it appeals to a far smaller market thus creating a smaller chance of selling it and then incuring bigger reductions in the price during its time being up for sale..Ok you could go by the factor of listing it high to give a bigger margin of price reduction but still making good money. But this guy selling the 330bhp S3 isnt budging so thinks the car is worth this price because of mods but infact its overpriced and probably will have to reduce it in the near future if Ryan doesnt buy it..
  26. Ryan_W
    Ryan_W Member
    336
    He said he'd go down to £8,400 :blink:
    I said to him that he paid over the odds for it when he bought it and that the mods don't justify the high price.
    Think I may go for one of the cheaper, standard cars and tune it as I go along, little bits each moth. This will save me money at of now, which can then be put towards an engagement ring for the ever hint-dropping misses! lol
  27. IrishDave
    IrishDave Active Member
    682
    45
    My advice would be not to rush into buying any of the above. I had been looking for over 3 months until I found the right one at what I would consider a good price and in good condition. They are out there its just a matter of waiting. Just my 2cent
  28. CasperS3
    CasperS3 New Member
    20
    Modified vehicle is overpriced..... good spec. but I personally wouldn't touch at that price. In a few years time 330hp will be less special. Stage 1/2 8p S3's and BMW 135i's with a basic remap make north of that already. With a BT modified S3 competing against these cars once they drop further in value will make a heavily modified 12/13 year old S3 worth peanuts. Top money may still go to immaculate standard cars though.
  29. Ryan_W
    Ryan_W Member
    336
    I've told the guy, if he'll drop to £8k, he's got a deal... Do you think in all honesty that I may still be paying over the odds?
    I'm definitely not rushing into things, I've been looking at S3's since last July when we bought the 135i. The 330bhp car does tick a lot of my boxes though, and if I could get the interior mint, the car would be perfect.
    Decisions, decisions......
  30. Agric04
    288
    Ryan_W I see you're practically on my door step, if you need any help looking at S3's give me a shout, I've got a full version of vcds if you need to do any diagnostic scans.
  31. S£
    S£ Member
    683
    I've just seen the big turbo one on piston heads, I'm not 100% sure but that might be glen jai's old car?? (anyone) he sold it last year..
  32. thegoal007
    thegoal007 Another S3 owner....
    801
    26
    totally agree mate .
  33. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,083
    180
    I'm not sure you can expect someone to spend thousands of pounds tuning a car not to want to sell it at a higher price after all of the work.
    I'm going to be spending £12k, roughly, on buying and modding mine to a similar level so if you can get him to £8000 thats sounds like a deal to me. You'd have to spend 4k on putting things right to spend as much as me, which, if you've checked it thoroughly and your satisfied that it's been looked after should be hard to do. Just my thoughts...:icon_thumright:
  34. Dane
    4,083
    180
    Although I see no mention of the rods being changed
  35. rhubarb4
    1,749
    184
    You seem like your heart is set on that one mate, go for it I hope he takes 8K for it. I used the bobble off on mine bought them up like new, I need to put some pics up of my new car, I still got my red one in my profile pic lol, my new one is silver half leather half grey alcantara.
  36. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    I'd say for the cleanest example, and worry about modding it yourself later. 225s aren't exactly slow, and getting up to 250/260 is simple as a generic remap. Get the right colour and options you want, and as low mileage as you can afford (assuming miles are genuine and the car's state reflects the lower miles). And remember, enjoy it!
  37. Agric04
    288
    I say if the modded one is the exact spec and colour you want go for it, but if not don't compromise and look for one that ticks all the boxes and gradually mod it over the years you have it. I had a quick glance at it on piston heads, love the wheels, but the base car looks to be a fairly basic model, no symphony stereo, no heated seats and is it actually Bose as I can't see any Bose decals on the door speaker grills from the pictures. Not sure I'm keen on the large sub in the boot, would be a lot better with an Andymac stealth sub. Will those seats not be a nightmare to keep clean!!
    I think the car is over priced, as people say I think a good standard car is worth more than a modified one, unless it is absolutely what you are looking for. Have the engine internals been upgraded? I think if they haven't then personally I wouldn't touch it, only my opinion and I'm very new to the modded car scene!
    Bare in mind a good standard car with a remap up to 260bhp makes for a quick car with reliability.
  38. Ryan_W
    Ryan_W Member
    336
    Can anyone confirm this?
    Here's a pic of the car:
    If it is running 330bhp, would the internals have been upgraded, or is that something that would need doing. Bear in mind that the cars done 12k miles since the big upgrade in HP. What about head work etc?
    Cheers,
    Ryan
  39. Ryan_W
    Ryan_W Member
    336
    Thanks a lot for that offer mate. I'm off to view one today in Royston. Shall see how that stacks up against the 330bhp one. The money is in my hand and I just want an S3 on my driveway!!!
    I'll PM you on here after I've been to see it with a few Qs.
    Cheers.
    Ryan
  40. Ryan_W
    Ryan_W Member
    336
    After some internet research, I found this from July 2009:
    Audi S3 330BHP 51/2002 Facelift
    Audi S3 Quattro 3Dr 51/2002 Facelift 330BHP Nogaro Blue, Full Service History, MOT Jan 2010 & Taxed to end Jan 2010, 71K Miles, Recently Serviced at Bavaria Autowerke Aberdeen in Jan 2009, Xenon Headlights, Full Black Recaro Leather, Aluminium Mirrors, Audi Concert Sound System with 6 CD Changer & Audi iPod Connection, A/C, Electric Windows, Electric Heated Mirrors, Cruise Control, PAS, ABS, Traction Control, Cargo Net, Clifford IG950 Alarm with Callguard & Intellistart Remote Ignition. Handling & Performance completely transformed compared to standard S3 with over £15K of upgrades. Located in Aberdeen.
    Engine
    475cc Injectors
    Apexi AVC-R Boost Controller
    ATP 3" Turbo inlet pipe
    ATP Eliminator GT28RS Turbo
    ATP Induction kit
    Supersprint Cat Back Exhaust
    Miltek 200cell cats
    Forge 007P DV
    Forge Alloy Oil & Water Covers
    Forge Alloy Strut Tops
    Forge Dog Mount Bush
    Forge Fluorosilicone Turbo Hose
    Forge FMIC
    Forge Intercooler Hoses
    RS4 MAF
    Star Performance Custom Mapping
    De-restricted charge pipe (Not Currently Fitted)
    Transmission
    B&M Shortshift
    Haldex Performance Controller
    Helix Clutch
    Helix Lightened Flywheel
    Suspension
    Custom Alignment
    Eibach Pro-Street S Coilovers
    Eibach/Neuspeed Front & Rear ARBs
    Forge Rear Tie-Arms
    Powerflex Bushes
    Brakes
    Porsche/ECS Big Reds
    HT-10 Race Pads
    ECS 308mm Rears
    Pagid Fast Road Rear Pads
    Wheels
    New RS4 Reps 8x18" et35
    Goodyear Eagle F1 225x18x40
    McGuards Locking Wheel Nuts
    Forge Spacers
    Interior
    Black Leather Electric Recaro Interior
    Audi iPod adaptor
    Cargo Net
    OEM Cruise Control
    TT Pedals
    Exterior
    Aero Wipers
    Aluminium Heated Mirrors
    Security
    Clifford IG950 with CallGuard & IntelliStart
    Just back from Professional Detailing service including Paint Correction, so is in Fantastic Condition.
    This is a excellent example.
    Sevice History is as follows:
    24/09/2001 0 Miles @ Wealer Audi, Heerlen. Dealers Delivery Inspection
    01/07/2002 Imported & Registered in UK
    08/04/2003 10,814 Miles @ Lincoln Audi. Longlife Service
    22/03/2004 21,492 Miles @ Specialist Cars Audi Aberdeen, Longlife Service, Brake Fluid Change, Oil changed in Haldex Coupling.
    30/05/2005 38,615 Miles @ Specialist Cars Audi Aberdeen, Longlife Service,Air Filter Element renewed & housing cleaned, Fuel Filter replaced, Spark Plugs changed, Hydraulic Fluid level checked, Oil Filter changed in Haldex Coupling,
    28/04/2006 46,923 Miles @ Star Performance Kirkaldy, Inspection Service Oil Change Service
    02/12/2006 54,443 Miles @ Star Performance Kirkaldy, Inspection Service Oil Change Service & Inspection Service
    12/03/2007 58,211 Miles @ Star Performance Kirkaldy, Inspection Service Oil Change Service & Inspection Service, Brake Fluid Change, Oil Changed in Haldex Coupling, CamBelt, Rollers & Tensioners replaced
    28/11/2007 63,474 Miles @ Star Performance Kirkaldy, Inspection Service Oil Change Service & Inspection Service
    16/01/2009 69,507 Miles @ Bavaria Autowerke Aberdeen, Inspection Service Oil Change Service & Inspection Service, Brake Fluid Change, Oil Changed in Haldex Coupling
    £8,250 ONO
    :ohmy:
    The guy selling the 330bhp silver S3 was obviously over charged and now expects me to follow the suit... I don't think so!
    Keep your eyes open for me chaps! If you know of any S3's for sale, PM me!
    Ryan
