Buying a Used S3: Checklist
Routledge Dec 23, 2011
  1. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    I know there's so much that you need to look out for when buying an S3.
    I made a list of stuff to check over that helped when choosing my friend's car with him - We're picking it up later on today.
    There's probably more that needs to be looked at, but thought that a good chunk of it would be useful to have written down in a checklist to take with us. There are other things such as listening out for knocking, getting under the car and checking condition, and so on and so forth..
    But yeah this is what we took along:
    [TABLE="width: 611"]
    [TR]
    [TD]Criteria
    [/TD]
    [TD]Comments
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Temperature dial after a run
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Roof guttering - Rust/corrosion
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Tyres - Tread left? As advertised?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Tax?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]MOT - Is it (X) months as stated?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Previous MOTs to confirm mileage
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Clutch
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Cambelt/Water pump? When?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Brakes - When changed? Discs as well?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Advisories on MOT
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Clutch pedal? Any wobble?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check previous owners number matches
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]HPI check - Make sure not written off prev
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Alloys - Check for curbing and corrosion
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check all lights work
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check for ABS/Traction Control lights >3kRPM
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check for pixel loss on display
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check stereo for issue with volume
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check speaker grills for Bose signs
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check gearbox - Notchy?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check for oil/coolant and make sure none mix
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check for exterior damage/linup of panels
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Check all interior for rips/tears
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]When was the last service? What was done?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Any oil leaks in engine bay/under car?
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [/TABLE]
  2. sportstractor
    sportstractor Chugger
    2,709
    I can add to your list.
    Check alarm siren is working, it probably won't.
    Check all wheel drive is functioning, if it spins up in first, it's not working.
    You have mentioned stereo problems, this is pretty likely if it has Bose. Avoid having the Bose system if at all possible... It's cack.
    Also check the over run water pump!
    Have fun
  3. Routledge
    392
    10
    If people want to keep adding in stuff then I can edit it into the first thread and maybe have this up as a Sticky for any potential S3 buyer to refer to?
  4. <tuffty/>
    21,010
    3,771
    Sure thing... lets see how it goes and I will prune the irrelevent stuff out for you as we go if you wish...
  5. Mings
    Mings A3 1.8T Sport
    77
    Nice one Routledge, I'm sure a lot of this stuff will be useful for prospective a3 buyers as well :)
  6. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
  7. <tuffty/>
    21,010
    3,771
    LOL... typical... I bang on about no one reading the bloody stickies all the time and didn't notice that one myself... :D
  8. mk1chopper
    mk1chopper Missing the S3
    1,092
    in fairness this is a checklist to take along which would be usefull, the buying guide is a good place to start for info on the S3 if your considering buying one and want to know more about them, this checklist will be good to take along on viewing as Routledge did for his mate.
    I would add check xenons move and adjust when first turned on, although the S3 lights dont seem to move much but if someone is out side they will hear the motors.
    Check aircon blows cold
    Check heated seats work if present
    Check seats adjust
    Check glove box hinge inst broken.
    Check spare wheel and tools are present
    Check lower door trim/rub strips for rust
    If car has FASH spend 5 mins on the phone to Audi and confirm service history.
    Notchey gearbox - I find with mine its notchey when cold between 1st and 2nd but once warm the gear shift is fine, check its not notchey once warm.
    Check springs arnt snapped or ARB collers broken
  9. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Check lower door trim/rub strips for rust + 100000000
    ^^^Expensive fix if its progressed.
    Start it from cold and see how rattly it is on startup.
  10. Perplexer
    Perplexer Member
    236
    Should I mention the Xenons self adjusting when you first put them on?
