Bushes shot to sh*t!
RichA3Turbo Apr 9, 2005
  1. RichA3Turbo
    5,089
    So recently the car has been a bit sloppy and the steering has been very slack.. Today i found why.
    The old ones were shot to sh*t! There was very little runner actually connected anymore so no surprise there was some weird creaking and sloppy steering and **** handling!
    I've got some ECS Poly bushes to replace them with however there was no way i wan going to be able to get the damn things in so will take them to AmD on monday with the arms and get them pressed in. Dont have the use of a proper vice at the mo (on list of toolage to buy).
    The old ones took some shifting.... drilled round the edge of bushings then bashed the main bit out and then used a blow torch and burnt the rest of it away.
    I also changed the tie rods (complete) which were a bit of a bugger also but got there in the end.
    Rich
  2. hopper
    hopper Member
    122
    its a bit late now mate but with bushes i normally try and get the centre out 1st, either just knock it out as with yours cuz they're totally knacked or burn the bush out. then get the air saw and cut throught the outer of the bush, then they just knock out.
    this may be useful in the future or to any1 else attempting this but a word of warning, dont go mad wen cutting through the bush as you may cut into the lower arm and you dont want that, just take your time.
  3. RichA3Turbo
    5,089
    It was pretty straight forward...make a few drill holes then bashed the main part through and then used a chisel and blow torch (at the same time) to remove the rest.
    Rich
  4. ANDYTQ
    ANDYTQ Well-Known Member
    1,185
    106
    I think mine are on the way out too,but i might put s3 wishbones on instead of just new bushes,i might get some camber adjustment then! /ubbthreads/images/graemlins/beerchug.gifAndy
  5. HTC
    HTC Active Member
    3,428
    9
    When I replaced the bushes on my old golf, I just replaced the wishbones as well.
    Saved me loads of time, but they were only £15 a side at the time. I imagine the A3 ones are more expensive. Hmm, I might check that out.
  6. RichA3Turbo
    5,089
    If i was using standard bushes i would have done that but i want to use poly bushes so wouldnt have helped much unfortunately.
    Rich
  7. Markb
    Markb Active Member
    2,139
    Kind of looks familar.
    Mine were the same and the steering was pants!
  8. RichA3Turbo
    5,089
    Well the new Poly bushes are in and the car does feel much better. Its holding the road much better on corners but that really isnt surprising seeing the state the old ones were in! Need to get the tracking checked now i've done the tie rods but all seems well. The poly bushes are also not harsh which i was expecting. generally impressed.
    Rich
  9. Ess_Three
    Ess_Three Active Member
    5,383
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    Rich, poly bushes are not that 'hard' but they do let in more road noise.
    A worthwhile improvement, in certain areas though, none the less.
    BTW, some of my S3 bushes & track rod (drivers side) were in a similar state at the car's first MOT! 2 years and 11 months after buying it new.
    Not good...
  10. RichA3Turbo
    5,089
    [ QUOTE ]
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    Not good...
    [/ QUOTE ]
    Thats no good. I believe mine were original items...considerably older than 3 years!
    there is a very slight increase in road noise... but nothing drastic. A worthwhile upgrade i feel.
    RIch
