Burning drivers door lock !!
951 Mar 6, 2009
  1. 951
    951 Member
    530
    Went to move my car which started fine this morning but the battery was now flat so i started it using my booster and left it running to charge the battery it was then i smelt burning and smoke started comming out of the drivers door card and when i touched the door lock i burnt my thumb ,it was just like touching a boiling kettle !!.I was starting to panic by this point and its the quickest i have removed a door card to unplug everything(yes i know now i should off disconected the battery but didnt think at the time). Ive found a black box on the inside of the door which was also red hot and smelt of burning it says heiz element on it so i presume its for heated door locks which i didnt know i had. Does it heat the mirrors as well,are they prone to buring out and should i replace it with new one or just not bother putting one back in ??
  2. aragorn
    18,137
    765
    (13) 4A0959981A
    control unit for heated door handle-lock cylinder
    Thats the control box for the heater in the lock cylinders. Although if its got as hot as you describe i suspect something must be a little broken with it!
  3. 951
    951 Member
    530
    Im not sure if its the box that was faulty or maybe something in the lock cylinder caused the box to burn out ??
  4. 951
    951 Member
    530
    Ive just prised the control box apart and its completely burn out ,apears to have started from a 3 pin resistor/chip !!
  5. aragorn
    18,137
    765
    thing is, did the door lock element short out the blow the control box, or did the control box die and cause the element to run overtime.
    I'd put another control box in and see what happens.
  6. 951
    951 Member
    530
    Thats exactly what i was thinking,if can get another from the local breakers i will give it a try but to be honest i might just leave it without as untill today i did'nt even know they were fitted and i dont use the lock's anyway !!
  7. moschino
    moschino Member
    252
    If you don't use the locks then why bother replacing the unit. Just disconnect it so nothing else can happen in the future.
  8. Broken Byzan
    13,237
    465
    If you dont use them then dont bother. It may throw a code in VAG but no serious consequences i can think of
  9. 951
    951 Member
    530
    I got one basically for free in with the centre console parts i bought. I fitted it yesterday and the car is not on fire yet !!
