Burn all Haynes Manuals
audinary Mar 7, 2010
  1. audinary
    audinary Complete And Utter Member
    676
    Began work on the front n/s hub bearing at about midday today, within 5 minutes I realised I don't have a 14mm hex drive (needed for driveshaft bolts).
    Stopped work, went to Colchester to obtain said hex drive, returned home. 20 minutes later, needed an 18mm spanner (weird size) . Do I have one? Do I bolox. Managed to blag one within the family and carry on with work.
    Why can't the Haynes manual preface each job with a "you will need" list with bolt sizes etc?
    Also, when it says "separate the ball joint, being careful not to use pressure against the ball joint rubber" why not actually give a few tips, rather than just what not to do?
    Anyway. The hub carrier is now off and half the old bearing is out, it's now far too cold to do owt in the garage. I guess I'm just sore about having to drive the spare car to work tomorrow....
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,878
    717
    Not even Elsawin states the socket sizes, it's a PITA and would love to know why the Audi manuals don't give this information, you would think it would help the mechanics. I feel your pain, I just did the clutch and to remove the gear box with the engine in situ uses all sorts of spanners, sockets, allen keys etc etc.
    One thing I have noticed more and more is they have lifted some of the text & images straight off elsawin
  3. audinary
    676
    Really? Doesn't suprise me. Also, when the manual suddenly says "to do this, refer to section 10.4" in which you have toremove the sodding axle or something daft.
    I'd love to get to the point where I only need the manual to point me in vaguely the right direction...
  4. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    This cracked me up, i'm the same when i alway's need something. I get to the point and think how many more tool's do i need to get me out of this sh*t
  5. audinary
    676
    Heh, I know. Then you buy the fookahs and never use them again...
  6. therealnovaboy
    therealnovaboy Missed A Gear
    43
    did exactly the same thisng a few weeks ago. bought a socketed allen key ready for the job. i bought a 12mm didnt i not a 14mm. 20min drive sorted that to find the bolt was solid and chewed the hex so i had to drill it out anyway.
    haynes is pap. the only thing there good for is torque settings.
    try www.audidiy.com the write ups are good.
  7. audinary
    676
    Victory is mine! Old bearing out new bearing in (A big shout to Gav at work with his hydraulic pressmanship) and three hours of clattering around with hammers and torque wrenches and the car is back together again.
    For anyone about to do a hub bearing, ******* jobs are:-
    Unbolting the lower transverse arms from the hub carrier (Need 18mm spanner, no space for a socket)
    Routing the ABS Cable back through the hub carrier and out to the firewall (Take a photo before you dismantle it, like I should have)
    And, if you're working in a confined space, maneuovering the hub carrier back onto the five ball joints is an arseache and requires two geezers and several cans of lager.
    Anyway, all done, car drives fine, no rumbling groaning sensation any more and a hyuje saving over proffessional labour costs to go towards suspension / remap / facelifts (one day...)
  8. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Haynes are gash....They don't even cover the V6 engines.....
  9. aragorn
    18,490
    855
    isnt there a haynes specifically for the v6?
  10. Matt82
    Matt82 Active Member
    2,365
    18mm haha
    my friend was stuffed this weekend whilst changing the suspension on a golf. everything on the golf is 13mm, 15mm, 17mm, 19mm but two of the suspension bolts are 18mm and he didnt have that :D
  11. phoenixv6quattro
    1,396
    nothing i've seen, or untill now, heard of.......
  12. audinary
    676
    Exactly. What a perverse size to use. The home workshop is pretty comprehensive, but after scouring the place the only 18 we could find was an old open ended Yamaha spanner from Dads' two-stroke years!
  13. Matt82
    2,365
    i dont have an 18mm spanner. when i get tool sets i always to get set which include all sizes within the range, but somehow i ended up with a clarke spanner set without an 18mm spanner
    i do have an adjustable pipe spanner tho that takes care of most eventualities
  14. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    theres not a specific one for the V6 but it includes it in the haynes manual
  15. phoenixv6quattro
    1,396
    The Haynes manual I have, and I have phoned them and asked if it is the sole B5 one they have, which it is, DOES NOT COVER THE V6 ENGINE.......................I have one, and there are no V6 repair guides/service etc...
  16. audinary
    676
    Should I bring some matches?
  17. Mr K
    Mr K Member
    335
    The haynes doesnt cover V6s, Quattro, or autos iirc, which made it bloody useless on my car!
    And yup, check you have a decent 6 sided socket and spanners in 17 and 18mm before doing your wishbones! a good ally drift / copper hammer (pinch bolt), some good haxsaw blades (some cant be extracted without taking half the car appart - so best cut and put back in the other way around) and a hell of a lot of luck (again, pinch bolt).
  18. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I looked at one in Halfrauds and when I read what it didn't cover it appeared I already knew more than they did!
    had one I used religiously when I rebuilt a Mk2 Golf.
    Agree with the advice things...nice to know bits would be useful.
    Like...."make sure you put the cam caps on the same way round that they came off, they crack if you don't!"
  19. aragorn
    18,490
    855
    Erk, that would be new head time then!!!
  20. jcb
    4,132
    13
    actually I managed to get the cap welded and it was almost spot on, quick polish inside and it was golden.
    still running today
  21. aragorn
    18,490
    855
    yikes that was lucky!
    Mate of mine had a worked head (think it was a honda vtec item) in his workshop, spikey cams installed and ready to fit to their motor. They had a break in, and amongst other things the twats whipped the caps off and stole the camshafts AND the caps. Unfortunately that meant not only was the camshafts a loss, but the cylinder head was effectively scrap too, becuase the caps are line bored at manufacture, meaning only the original caps will match the head.
  22. Geeman
    Geeman Low Life
    1,318
    I used Haynes manuals when I was younger... Mk2 Golf's, XR2's, etc. but now it's all about the internet and the VERY helpful forums!
  23. audinary
    676
    XR2s aren't a problem, it's just knowing which hammer to use.
  24. voteforpedro
    voteforpedro Member
    632
    I have an 18mm spanner... Bought it from Halfrauds specifically for something. Probably something to do with my old Golf.
  25. Broken Byzan
    13,237
    465
    I have 2 x 18mm sockets, 2 x 18 spanners and the same in 16mm over and above the "normal" sizes. Pretty much take apart any Audi now, LMAO
    Did i learn the hard way......
    Maybe :asskicking:
  26. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    I can say with some degree of certainty that you've actually got 1 x 16mm spanner mate. :detective2:
    One's on holiday in our shed following my finding it during the tidy-up last night :lmfao: (And now it's posted here, the 'safe-place' can't be forgotten! :thumbsup:)
    //R
  27. audinary
    676
    I have an 18.7mm open ended spanner now, after bashing the living shiz out of it during the bearing change...
  28. nomadx
    nomadx Member
    tbh, If Haynes manuals had handy tips on every awkward process, they would be twice the size they are now, and twice the cost. That is all stuff you pick up with working on cars overtime I am afraid. As for tool sizes etc, I agree it would be useful, but very hard to do as the size / type of fixings used can change year to year, and with some manufactors, from car to car! They sometimes don't cover certain engines or transmissions as there is not the demand, in their eyes, to do so and still make a profit.
    Treat them as reference manuals rather than how to guides and they are very useful.
  29. audinary
    676
    Here I am, cash waiting, for the first person who compiles such a manual. I'm no master mechanic, but I'm damn good at following instructions.
  30. S4twiggy
    1,815
    9
    wots this then?
    HAPPY MATE!!!
  31. S4twiggy
    1,815
    9
    covers the 1.8T and V6 engines
  32. Broken Byzan
    13,237
    465
    Thats an old US one I think, they don't make that one any more it's the newer blue one for us that only does A4 1.6's to 1.9 TDis, not quattro at all.
  33. S4twiggy
    1,815
    9
    yea i got both mate, no they dont do the quattro for some reason. wish they bloody had one for the S4 lol
    your right about it being a US version aswel, i remember my old man getting it from over there, think its a newer version though as it covers up to 2001 models.
