BULB REPLACEMENT G4
vw754 Feb 1, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,336
    58
    can i use a G4 12v halogen bulb for interior footwell lighting? (replacing the original 5w 501 bulb?)
    REASON FOR THIS IS 5W 501 NOT VERY BRIGHT
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
  3. vw754
    2,336
    58
    THE G4 IS 1O W AND THE 501 IS 5W.
    With the 501 you cant even tell there's footwell lighting fitted.
  4. enda1
    enda1 Member
    436
    You need to check the fuse rating on the circuit. If you put 10W in series with the interior light you are increasing the current draw on the circuit and if the fuse isn't rated for the load it will blow
