Bulb out warning
vroomtshh Jan 25, 2012
  1. vroomtshh
    vroomtshh Active Member VCDS Map User
    362
    49
    My car has the partial DIS.
    Should this give me bulb out warnings?
    I currently have 1 sidelight and 1 numberplate light out, and nothing on the dash?
    If I change my stalk, and code in full DIS, does this enable bulb out warnings, or is it a completely seperate system and I don;t have it?
    Its a 2003 Avant Sport Quattro if it matters
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    i cant comment on the full dis question but my 1st bit of advise is change the bulbs 1st :icon_thumright:
  3. vroomtshh
    362
    49
    And that will let me know if I have bulb out warnings? :shrug:
  4. quattrojames
    14,050
    574
    By "partial DIS" you mean just the DTE (distance to empty) gauge? If so then no you won't have bulb out warnings.
    If you fit the full DIS it will give you the warnings, a new stalk and coding should be enough, but you'll need to do extra to get the low screenwash indicator too. There are quite a few threads on this which can point you in the right direction.
  5. vroomtshh
    362
    49
    Yeh I have the distance to empty, and it tells me oil coolant etc.
    I already have the screenwash sensor in place (it hasn;t run out yet til I see if it works)
    Thanks for the info. I've got it figured out how to do the full DIS, I just wanted to know if bulbs were a part of that or if mine wasn't working
  6. marktdisport
    marktdisport Active Member
    1,195
    15
    mines got partial DIS and does not show any warnings when a bulb as blown recently changed headlight, sidelight, and stop light bulb with no warnings
  7. Les 51
    Les 51 A pint of Diesel please!
    687
    Mine has full DIS, but I don't think it tells me if the numberplate light is out. It tells me all the others.
  8. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,178
    151
    Mine had partial and used to show bulb out.
    Now it's full dis and doesn't.
  9. quattrojames
    14,050
    574
    Strange, was that a retrofit or oem spec?
