Bulb Out warning light still on
Dibbler Jan 1, 2012
  1. Dibbler
    Dibbler New Member
    Hi all,
    So checked and changed the brake lights ,change a couple of small bulbs in the 3rd brake light ,
    and still the damn light comes on and beeps ,where do I find the monitoring relay ?
    any other ideas would be appreciated
    Thanks in advance
  2. Broken Byzan
    13,237
    465
    change all of the bulbs in the 3rd light, worn ones can and have caused problems before now
  3. Oranoco
    Oranoco Well-Known Member
    3,799
    349
    Had this exact issue on mine and it turned out to be a slightly iffy brake light bulb in the o/s cluster. Everytime I checked the lights worked but a few minutes after the warning came on again.
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    I hate the third brake like on avants.
    All them little fiddle bulbs.
    I replaced all bulbs with 5mm RED LEDs and wired in a resister. No issues since. :)
    I can make one for any one else that wants a LED 3rd brake light.
  5. Broken Byzan
    13,237
    465
    go on then, i'll have some....
  6. ScottD3
    15,161
    1,121
    Some?
    How many 3rd break lights do you have? :)
    I can do Avants on exchange +price of the leds basis but not done a 'loon one yet.
    Arnt they just 1 bulb in the midle?
  7. Dibbler
    Dibbler New Member
    I like that idea ,how much ?
    those tiny bulbs are not cheap ,so far 4 brake light bulbs and 4 of the small 3rd light bulbs ,
    it is now getting personal :)
    next route would be the bulb monitoring relay ,but not sure where that's hidden ,have a local breaker with 3 or 4 Audi A4 saloons in atm
    if any one has a guide to the relay location ?
  8. Broken Byzan
    13,237
    465
    Its located under the drivers knee bolster big black thing with 387 written on the top. You can see it from the fuse access hole, but unless you have small hands, will not get it out
  9. ScottD3
    15,161
    1,121
    What ever the cost of LEDs are really.
    I've only ever done an Avant light and have no idea what a saloon light look light.
    I'm more than happy to take a look at a saloon light if someone wants to send me theirs.
    I can do avant lights on an exchange system since I have a spare one here.
    The resister you need is on ebay.
    Its a 501 resister for about £3.
  10. aragorn
    17,956
    701
    I have a couple of spare saloon rear lights here, so i could probably post you one to have "in stock" if you wanted.
    I've taken one of them apart, and they have four standard 5w 501 wedge bulbs fitted, so i'd imagine you can probably get away with using a standard 501 sidelight LED bulb that are commonly available, rather than going to the effort of soldering them etc.
  11. ScottD3
    15,161
    1,121
    That would be cool if you don't mind.
    I can see if I can knock something up.
    But to be honest, I can't see the point in soldering in LEDs when you can buy some 501 LEDs from T8ups.
  12. Dibbler
    Dibbler New Member
    Thanks ,
    Hands like shovals :( , so now where to borrow a small child from ?
  13. Broken Byzan
    13,237
    465
    I'll hit up T8ups then, see what he has. In the 7 yrs of B5 ownership, i've never had to change a bulb in one.lol
  14. Dibbler
    Dibbler New Member
    So the Saga continues ,
    I have now replaced the 387 relay ,chnaged the brake light bulbs so so many times ,replaced the tiny 3rd brake light bulbs ,
    for the love of god I still have the warning light on !!!!
    Anybody else any ideas please .
  15. aragorn
    17,956
    701
    Wrong wattage of bulb fitted somewhere? Or a single filament bulb where there should be a twin filament or vice versa?
    Have you actually checked for proper functionality of the brake lights? IE got someone to press the pedal while you inspect for correct operation?
  16. Dibbler
    Dibbler New Member
    Yep checked brakes lights ll working ,checked voltages ,replaced all bulbs with correct voltage etc ,running out of ideas now
  17. Mackers
    Mackers Member
    291
    ooooh, wanna make us one up too, as i have a dodgy bulb that annoys me knowing it's faulty (now and again), i've a "X"Reg avant (A4) are the LED's wide angle ones too, also how much, feel free to PM me,
    Many Thanks
    Wayne :D :D :D
  18. ScottD3
    15,161
    1,121
    I'll dig out night pics of mine tomorrow and pm you.
    Dibbler, have you checked all connectons to each bulb to make sure its nice and clean?
    earth points?
  19. Dibbler
    Dibbler New Member
    So today ,stripped and cleaned all connections to the bulb holders, changed the 387 relay for 2 others I acquired from breaker ,and that is a job in itself they can't all be faulty ,
    Checked all lights worked and ......... on came the warning light straight away ftlog off to buy more of the tiny 3rd brake light bulbs could only get 6 from local shops so still four to change and see if thats causing it (even though all lights work)
    not much else to try ,
    Would the brake pedal switch cause the same symptoms ?
    At first the warning light occasionally came on now its permanently on ,how I miss the OK when I turn ignition :) ,the beeping is now
    grating
    Any other ideas please would be greatly appreciated .
  20. B5 BIKER
    B5 BIKER Member
    266
    Have the same problem a couple of months now.
    Changed all the bulbs for Oem spec, changed the relay, changed the pedal switch also and still no joy.
    Only thing I have noticed is that it's worse when raining and only happens intermittently when dry
  21. Lanmanager
    Lanmanager New Member
    Posting this for anyone that comes across this issue with no seeming cause... My issue turned out to be a cheap dual port USB plug in phone charger. The hint was I would hear my phone connect/disconnect sound and and instantly the brake light warning would come on. With two phones charging the warnings were non-stop. The charger was either generating noise or pulling too much load on that circuit. Whatever, popped in a new charger and the warnings stopped.
