Bulb Light Error
Dibbler Dec 12, 2011
  1. Dibbler
    Dibbler New Member
    Hi all,
    had the bulb error showon the DIS then an annoying bleep all the way back on a 3 hour drive :(,
    I have checked every bulb and can't find any not working ,it is now errtic when it starts out showing ok then sometimes
    starts flashing error again ,
    has any one any ideas ,thanks in advance
  2. aragorn
    17,877
    687
    What does it look like? It only monitors a few bulbs, mainly headlights on the front and brakelights on the rear.
    Brakelights symbol looks different to the headlight one though.
  3. Dibbler
    Dibbler New Member
    Damn :),I'll have a look and post a picture ,thanks
  4. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Not wanting to worry you, but that is what I had starting to happen with my wife's car here, DIS dead However, all this may have been caused by a not great battery!
    One of the clues was it would be a little slow to start, then the voltmeter would take an age to come up. Once up to 14V (ish) it was fine.
    If she put on heavy electrics before it was at 14V (alternator online) the voltage would drop off. At some low voltage point she had the bulb warning go off.
    Of course, it could also be the bulb monitoring unit in the drivers footwell under the dash.
