Has anybody managed to find and disable this setting (and increase the voltage, and subsequent brightness to dipped halogens) for the 8v model.
Searching, I have found lots of good advice to go to;
-central electrics
-coding 07
-Byte 19
- bit 0-3 to drop down menu, where the voltage table should be for adjustment or the disable facility
I think this must have changed with the 8v model as using VCDS I can get all the way to bit 0-3 but no drop down menu or anything about headlight voltage . It could be that this facility is no longer available but it would be good to rule it out if so.
Anybody found this setting elsewhere and could point me in the right direction please.
-central electrics
-coding 07
-Byte 19
