Bulb Help
estwing Nov 22, 2010
  1. estwing
    estwing Member
    55
    Hello,
    I am after a little help with some bulbs.
    What fitment are the sidelight bulbs? are they w5w or are they something else?
    Also what fitment are the indicator bulbs on the front wings, and how to do remove the light housing to change the bulb?
    All info and advice will be helpful, thanks
  2. kirsty76
    kirsty76 Member
    255
    removing the indicator housing is easy there will be a clip on one side u just need to get something in there and press it in and it will pop out. i used a piece of hard but flexible plastic so not to scratch the car. i have 5w sidelight bulbs in my car as this is what the originals were.
  3. mike foster
    3,967
    Sidelight bulbs are w5w or 501's. Both the same bulb.
    To remove repeater press firmly against the lens and push towards front of car.This allows the spring clip to slacken off and you can just pull the lens out. Dead easy !
  4. estwing
    estwing Member
    55
    does any1 else have the xenon headlights like the ones that are on the s3's?
    Everything works but the xenons are really bim, they dont light up much of the road, what can cause this?
