bulb error on DIS - Help Required
Speedo Mar 4, 2007
  1. Speedo
    Speedo Member
    96
    Hi,
    I have a bulb showing and beeping when i drive the car. I thought it was the back left brake light which did not ignite on pressing the pedal. I changed the bulb and still no luck - as anyone else had such an issue and how was it resolved, something tells me its a wiring fault, however is there a way to test this? I have changed my backlights to the newer versions, however these have been on for over a year.
    On another note my temp gauge at times just stays on '0' even after like 15 mins of driving and on other occasions the dial is fine, this might be a sensor error or something to do with the wiring - any ideas?
    I have a A3 1.8T, 1998, any help would be appreciated.
  2. Speedo
    Speedo Member
    96
    Anyone? Any ideas?
  3. jonS3
    jonS3 Member
    719
    is your bulb warning light always on or random?
    temp guage could just be the coolant temp sensor?
  4. Speedo
    Speedo Member
    96
    bulb warning light comes on once i press the brake pedal (from a cold start) and then displays througout the journey.
  5. Speedo
    Speedo Member
    96
    and no its not random, its happens all the time.
  6. jonS3
    jonS3 Member
    719
    i know you say you've checked, but just make sure its not the brake bulbs, i had a dodgy one that worked sometimes and not others
  7. colinra
    colinra Member VCDS Map User
    91
    its unlikely to be a wiring fault. check all bulb connections in the rear lights. you can use a bit of sand paper to clean the connections. dont forget the third brake light as it has lots of small bulbs and it would only take one to give an error.
  8. steve1975l
    steve1975l Member
    595
    Yep I would clean all connections. When my 3rd brake light bulb went it didn't come up with an error.
  9. benk
    benk Member
    469
    I had a problem in my 99 A3 where the rear high level brake light would work intermittently. It turned out it was a loose connection in the bulb checking unit. Might be worth getting someone to check connections for you?
  10. jonS3
    jonS3 Member
    719
    2 of mine went and no warning came up
