Bulb change manual page
andywil13 May 12, 2014
  1. andywil13
    andywil13 Active Member
    380
    68
    Does anyone have the 8v manual with them that can upload a photo of the page that shows how to change he fog light bulb. Thanks
  2. h5djr
    9,423
    1,747
    Here is the page. Hope your can read it OK.
  3. andywil13
    380
    68
    That's perfect. Could you do the same for the replacement bulb types for the sportback with xenons
  4. andywil13
    380
    68
    Ahh don't worry. Ive just read its a misprint in the manual. It states H11 when it actually needs H8.
    Now to decide if I should modify the H11s or try and buy some H8s (or give up)
  5. h5djr
    9,423
    1,747
    The table in my manual says the Front fog light is a 35W (H8) bulb.
  6. andywil13
    380
    68
    They must have updated it. Mine says H11
    Much less choice for H8 bulbs
  7. h5djr
    9,423
    1,747
  8. andywil13
    380
    68
    Yea i don't know if LEDs will generate bulb failure errors as the energy consumption will be less possibly causing alerts
  9. Daveotto
    Daveotto Well-Known Member Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,877
    4,170
    Apparently, it is just a pin that needs bending out of the way. I had same problem on mine when I bought replacement fog lamps to match the xenons. T8ups, a member on here, supplied my xenon matched ones, but supplied H11's based on the manual, and eventually we decided to just swap them rather than mod them. Maybe he can advise on the modification.
    btw, the H8's which were eventually fitted (by my local garage as I could not be botheed with the messing around) are a perfect match for DRL's and xenons.
