Buggered Alternator
Russ Jul 26, 2010
  1. Russ
    Russ Member
    61
    Well it looks like the alternator's given up. Batteries not charging and the light's come up on the dash.
    Does anyone know where I can get a reconditioned one for a good price or if there's anything else I should check before I order it?
    Cheers all
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
  3. Welly
    10,696
    130
    Also, if you have a multi-meter, check the voltage across the battery terminals with the engine running. It should be 13 or more.
  4. Bignick
    Bignick Member
    165
    I just changed the bushes in mine it only cost £18, job done.
  5. Russ
    Russ Member
    61
    Cheers Welly, will have a look.
    Nick, did you have much trouble getting the alternator out?
  6. Welly
    10,696
    130
  7. Russ
    Russ Member
    61
    Sod it, if I break it then I'll just pay someone to fix it. Cheers peeps
  8. Welly
    10,696
    130
    No problem.
  9. Russ
    Russ Member
    61
    Ok so it's definitely the battery. Multimeter was reading 12.5v before I started the car and 12 with the appliances on and revving to 2k.
    Question now is, will a fully charged battery get me the 45 miles needed to get it to my parents where all the tools are?! :-s
  10. Welly
    10,696
    130
    Do you means it's definitely the alternator? Charging at 12 Volts is the alternator matey, as it's not really charging at all.
    Speaking from experience, it should last you 45 miles as long as fully charged.... No electrics on!!
  11. Russ
    Russ Member
    61
    Yeah I meant alternator hehe.
    I shall use natures air conditioning and hope I don't get stuck in traffic!
  12. Welly
    10,696
    130
    My advice is take fuses out of systems you don't need....
    I managed 120 miles on 1 battery with a shagged alternator at night....
    Scary, was on the motorway going as fast as poss with just front fogs on.
