budget poly engine mount
olds_kool Jun 28, 2009
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    while i had the front off to do cambelt i thought id try something out
    cheap poly snub mount using liquid urethane (sikaflex used for bonding windscreens, bodykits etc)
    started out by cutting a backing plate from thin aluminium as mounts hollow
    then put a layer of urethane and left it to harden for a bit
    mounted to engine and put in a load more urethane
    i decided to keep the original rubber mount as it was in good nick (just didnt do alot as it moved so much) and fill the space around it
    left it overnight to go solid
    result was better than the uprated mount i have on my tdi, alot less engine movement
    a budget mod that works!
