BT phone, contacts missing?
d5aul Aug 25, 2006
  1. d5aul
    d5aul Member
    I have two phones (work & Private) that I use with the Bluetooth Handsfree in the car, I switch between the two phones depending on whether I am out for business or pleasure.
    When I first got the car I had a SE K750i as a private phone & a Nokia 6230i for a work phone. both of these phones linked to the car & all the contacts showed correctly. A few months ago I changed the K750i to a W810i (very similar phone) again everything worked fine but recently within the last few weeks I have found quite a few contacts in the W810i do not show on the car.
    I know that the car is meant to automatically update new numbers but does not seem to happen, I am thinking I may need to clear the car memory & start again? does anyone have any advise on how to sort this out?
  2. icenutter
    icenutter Member
    596
    Check where the contacts are stored. I've had simmilar problems when things have been stored on the sim rather than in the phone memory. Next is to check 'how' they are stored. I don't have either of the sony ericsson phones you mention, but on some Nokia phones you you can store numbers under home/office/other etc. Check to see if there is any correlation. It might not pick up contacts in other.
  3. d5aul
    d5aul Member
    All the numbers are stored on the phone, none are stored in 'other' they are either home, office or mobile.
    When I first got the phone everything worked fine but recently the car does not show all the contacts, I have not changed any settings on the phone since it was originally paired to the car apart from adding a few numbers.
  4. simonwjones
    simonwjones Member
    365
    do you have any problems with the BT pairing dropping and then reconnecting.
    this is a symptom of a contact it cannot upload.
    Trying resetting the satnav and then repairing the phones, this should then reload all the contacts back to the nav unit
    Simon
  5. d5aul
    d5aul Member
    I tried re setting the SATNAV & re pairing the phone & that did not work.
  6. simonwjones
    simonwjones Member
    365
    Is the Nokia still working fine. Create a dummy contact on the nokia and see if it uploads to the nav ok.
    Could be a firmware issue with the W810
    run the Sony Update Service program that came on the Sony CD and it will see if there is an update available. Ive heard of problems with early k750 because of firmware versions.
    You need to eliminate something whether it be the nokia or the 750
    Simon
