  1. zbeasty
    zbeasty New Member
    I've looked at the tuning guide and done a search of the forum but can't seem to find if anyone has used this kit on a B5 A4 Quattro.
    CTS TURBO B5 A4 1.8T TURBO KIT
    CTS can't tell me if it will fit a RHD car so was hoping someone on here might have used the kit previously. It's a low mount not a top mount set up so don't know if this will cause clearance issues. I'm looking at getting it with the GTX3071 because they don't sell it without the turbo otherwise I'd probably just get a Forced Performance HTA3071. The other option is to buy everything separately and build my own kit.
    Advantage of the CTS kit is that it comes with everything to be able to just bolt on, add an FMIC, some injectors, a pump and tune away. Build my own means fabricating the pipe work, sourcing the oil and coolant lines plus all associated little bits that generally get forgotten till you have everything pulled apart.
    Any advice would be appreciated.
  2. aragorn
    18,306
    806
    Isnt that a knock off of the PSi Concepts manifold?
    If so, you should be buying it from them instead, they designed it.
    Exhaust Manifold - PSi Concepts Audi/VW 1.8T Longitudinal (T25)
    That way you can use your chosen turbo.
    I believe the manifold will fit just fine, theres nothing that changes the exhaust routing between RHD and LHD cars.
  3. zbeasty
    zbeasty New Member
    Thanks. I hadn't come across PSi Concepts before but their manifold does look good. They do a oil and coolant line kit which solves another of my problems. The last real issue is downpipe which they do in 2.5" but the HTA turbo I'm looking at has a 3" outlet :(. I've messaged them in case they can do the downpipe in 3". The mod costs for an as yet unbought car are quickly starting to escalate....may have to buy the wife a new handbag or something :)
  4. aragorn
    18,306
    806
    I'd just have the downpipe custom made locally to suit your turbo tbh.
    Also, incase you hadnt noticed, PSi do the manifold with both a T25 and T3 flange. I linked the T25 version.
  5. PaulJC84
    PaulJC84 Owner
    2,904
    17
  6. PaulJC84
    PaulJC84 Owner
    2,904
    17
    I remember also seeing a tastey looking tubular manifold from the states but it was twice the price of the psi one.
  7. zbeasty
    zbeasty New Member
  8. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    you can get a 200csi cat for pretty cheap. if and when i go bt. ill have the cat located under the car. or have it graphed in to a decat pipe. least that way you have the flanges, but would be simple. just measure twice, cut once and then weld in.
  9. zbeasty
    zbeasty New Member
    I'll be seeing the guys that did the downpipe on my R about a cat. They have 100 cell cats which flow really well :)
  10. boost-addict
    1,000
    39
    I doubht 100 cell will pass mot. 200 will be more than enough
  11. zbeasty
    zbeasty New Member
    We don't have MOT's here fortunately :) Once a car is 5 years old you have to do an annual inspection but that really only checks that all of your lights are working, you aren't leaking any fluids and that the brakes work. The only time you might have to do any sort of emissions check would be if the cops pulled you over for being too loud but then it would only be noise pollution not exhaust emissions.
