BSR Optiflow Air Filter A4 2.0T
mikeyw Nov 4, 2011
  1. mikeyw
    mikeyw Member
    137
    BSR - Optiflow kit, A4 2002
    ^This is the kit I have for sale.
    163 Euro, with vat and delivery was 205 Euro, which is £175.
    I'm wanting £90 inc delivery for it, which is obviously about half new price.
    Will try get a picture or the actual filter, especially if requested.
  2. razza1
    razza1 Well-Known Member
    3,055
    806
    tempting...what's the reason for sale, and how many miles have you done with it on?
  3. mikeyw
    mikeyw Member
    137
    It's done less than 2,000 miles. The gf was wittering on about the noise it made. Coming off throttle I did get some kind of turbo flutter noise back though it. More of a hissss when more aggressive though. Going onto throttle it's pretty throaty.
  4. Marrow
    Marrow Member
    587
    This is a bargin if I didnt already have one I would snap it up!!!!!!!
    Kit sounds great razza you should buy it mate !
  5. razza1
    3,055
    806
    ssshhhhhh...
  6. razza1
    3,055
    806
    did like the noise of the induction kit I had on my old car, however I think the missus will probably say the same as Mike's..
    anyone got any sound clips of it?
  7. Brendan12
    Brendan12 Member
    141
    So tempted...
  8. Marrow
    Marrow Member
    587
    I thought my wife moaned about my car alot sounds like i have an easy ride ! To be honest mine only makes a noise when i give it a boot full lije most induction kits
  9. mikeyw
    mikeyw Member
    137
    I'll upload a vid in a sec. Recorded with phone so it hasn't picked up the lower throaty tones, but you can hear the cha-cha-cha noise. Hopefully Marrow can confirm it sounds right. If not, something else is f*cked.
    VID 20110927 124734 - YouTube <<< might need a few mins to go live.
  10. chrisa4quat
    chrisa4quat Active Member
    970
    Any idea what these will sound like with forge spacer (dump valve). I might have it off ya
  11. mikeyw
    mikeyw Member
    137
    No idea but I have a spacer for sale too. Never had them fitted together though. Do you have the spacer on... and can you hear it?
  12. chrisa4quat
    970
    I do have the spacer. It isn't as loud as I'd have thought. Maybe I need this too :). Gotta wait for cheque to clear as been off work. If this is still for sale I'll have it. Cheque should clear Monday/Tuesday
  13. chrisa4quat
    970
    Will this fit 2006 b7?????
  14. Marrow
    Marrow Member
    587
    Yes it will mate mines a 06 and that noise is normal just turbo chatter i.used to have spacer fitted with this filter and the blow off sound was to loud for me with both alittle chav imoa but each to their own
  15. mikeyw
    mikeyw Member
    137
    Picture of it fitted. Can't see too much, because it uses original cold air feed, which goes over the top. Can also make out half of the heat shield.
  16. chrisa4quat
    970
    Don't see why it uses the original feed pipe. I'm guessing as most induction kits this is noise rather than performance. I do like the noise tho :)
  17. razza1
    3,055
    806
    The problem with most induction kits is it pulls hot air from inside the engine bay direct into your turbo, which isn't good for it. Most heat shields also do little to block this. This kit uses the cold air feed still, so although it may get some hot air, it shouldn't be much I would think....
  18. i3ai2t
    i3ai2t New Member
    If you've still got the bsr kit i'll buy it
  19. i3ai2t
    i3ai2t New Member
    Are you still selling?? I'll buy it for £90.
  20. Craig Cull
    Craig Cull Well-Known Member
    2,311
    1,106
    Hi mate do you still have the opti flow?
