Brown Coolant bottle
ScottD3 Apr 16, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Thursday I filled my old coolant bottle up with bleach, left it for 4 days, drained it out yesterday and it looked the same.
    In conclusion, you can't bleach your coolant bottle white again.
  2. wallace78
    wallace78 Member
    146
    I used dish cleaning tablets,worked a bit if that helps
  3. ScottD3
    15,161
    1,121
    Not a bad idea.
    I bought a new one and just playing about with this one.
    I might try that.
  4. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Wash it in the dishwasher, might be more effective?
  5. ScottD3
    15,161
    1,121
    Wont get to the inside sections.
  6. Reesy
    3,640
    148
    Dishwashers jet the water out, you do realise that?
    Failing that, just put it in the right way up instead of upside down...
  7. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    i tried that it did make a difference, then put it all together and it leaked around the middle....
    ended up buying one from bay of e, identical to ECP even same box, however word of warning the exisiting OE hose clips where no good had to use standard jubilee clips.
  8. ScottD3
    15,161
    1,121
    You do realise the coolant bottle has walls and sections with it it, it also have 1 semi large hole and its not round, its square ish?
    Really? how come?
    I bought mine from Audi and it was fine. apart from the plug. that was different.
  9. rasA4
    3,287
    119
    Hi Scott i didnt buy from Audi i bought an aftermarket one and the outlet pipes where smaller i guess
  10. ScottD3
    15,161
    1,121
    this the one you had at ADI?
    its now full of boiling water and a dish washer tablet.
    let's see what happens. lol
  11. dubster67
    dubster67 Member
    152
    9
    use radiator flush or that metal renovator stuff you get from B&Q, worked a treat on my TQS's rusted up header tank/coolant bottle.
  12. ScottD3
    15,161
    1,121
    I'll try that at as well.
    I might get some hydrochloric off my dad and see what happens. lol
  13. rasA4
    3,287
    119
    not sure i think so
  14. ScottD3
    15,161
    1,121
    It looked ok from what I remember.
    2 days in the dish washer tablet and water.
    No difference but it did remove alot of the gunk from inside the tank.
    I was shocked at the amount of **** that came out and a little worried.
    Next?
  15. wallace78
    wallace78 Member
    146
    sorry i meant dishwater tablets i put them inside andlet it steep for a few hours!!
  16. NineNails
    NineNails Proud sponsor of the snack food industry
    583
    I'd be keen to give mine a clean if a way could be found so this is an excellent experiment!
    What about trying dishwasher tab and some water and chuck the bottle in the microwave for a bit?
  17. ScottD3
    15,161
    1,121
    That wont work cause there is metal in the bottle.
    The switch, round the exit pipes and where the cap goes.
    Stain remover?
  18. aragorn
    18,036
    725
    you'll be surprised to know you can put metal in a microwave, so long as theres a conductive path between the chunks (water should do) and no sharp points you should get no arcing.
    I've microwaved spoons, forks, and even the metal foil takeaway dishes, they all work just fine.
  19. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    Or you could just pay £15 and have a brand new one delivered from gsf
  20. aragorn
    18,036
    725
    Or better still, close the bonnet and ignore it :p
  21. ScottD3
    15,161
    1,121
    Sod that.
    Last time I put metal in it sparked, smoked and went funky. lol
    Bought a bran new one and fitted it.
    This is the old one i'm playing about with.
    I got a new one.
    Seeing how much **** is coming out of this bottle is shocking.
  22. NineNails
    583
    Buying a new one is too easy! lol. I'd have a play myself but don't have a spare. What about Petrol/white spirit/turps? Put some gravel in there too and a good old shake for a while, obviously making sure to get all the gravel out after.
  23. ScottD3
    15,161
    1,121
    Might turps.
    I'll get some when I'm passing.
