broken rear spring
audiholic ste Sep 7, 2013
  1. audiholic ste
    audiholic ste Member
    171
    25
    Today the bounced the car up the pavement and broke the rear drivers side spring . Audi s3 8l 2000 . My question is do I have to buy a full set or can I just buy the rears and what spring should I go for apex hr ? The car has in my opinion always been stiff and I've felt every little bump in the road
  2. kryton
    kryton Member
    91
    10
    If your going to upgrade you will need full set but if genuine ones just get rear pair
  3. audiholic ste
    171
    25
    Bit of a mistake should have said . Today the wife bounced ....
  4. kryton
    kryton Member
    91
    10
    i got genuine ones off a breaker with 60k on it for 30 delivered , there are different coloured spots for different spring lvngths so make sure u gvt thv right ones .
  5. audiholic ste
    171
    25
    The springs are rusty as hell . Don't think I'll find any coloured spots on them or do u mean on the new springs if I go to a breaker ?
  6. jojo
    28,944
    3,598
    Buy new mate, used ones will go the same way, it's a known fault. I'd be going for fresh shocks too whilst its all off.
  7. jojo
    28,944
    3,598
  8. shady-ninja
    shady-ninja Active Member
    999
    53
    on a car that old I will change all the shocks along with the springs possibly with an uprated one.
    if its a basic 1.6 A3 then I will just change one spring.
    don't cut corners or else it might bit back in unfavourable conditions such as the wet.
  9. audiholic ste
    171
    25
    What's a good spring and shock combo . Don't want it stiff as hell and end up with a sore back . My back is bad enough through work .
  10. audiholic ste
    171
    25
    Being a numb nut when it comes to cars what's the difference between springs and shocks and coilovers .
  11. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,909
    747
  12. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    Bilstein's & Eibach Springs are decent enough. 20mm drop over standard, so not too bad.Springs & shocks are just that.Coilovers have the spring over the shock & are fitted as a single unit.Never used them as from what I've read they are generally hard as hell.
  13. audiholic ste
    171
    25
    New springs and shocks then .
  14. Lavis89
    1,909
    747
    i have coilovers on my car (the entry model AP coilovers) and i find them to be better all around than what the car had on as standard, but the standard suspension was 12 years old.
