Broken Ignition Barrel
bora11 Oct 27, 2013
  1. bora11
    bora11 New Member
    13
    Hi my ignition barrel housing has broken when I removed the Ignition switch a small blade of metal came out as well. I was just wondering if I just have to change the housing which the switch and barrel sits in as the switch and barrel look fine. Also I presume you have to drill or cut the two bolts of which hold the housing onto the steering column ? Any help much appreciated as the car is in bits at the mo :-( oh its a 1998 s3 )
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Ive never replaced one but I could get a new one to fit your key for approx 80.00+ pnp.
    You may be able to get a local locksmith to rebuild yours for you, doubt it would be that cheap though. Where abouts are you?
  3. bora11
    bora11 New Member
    13
    Thanks I have another barrel and switch it was just the metal parts inside the housing that has all broken. I am going to have to try and get another housing and try and remove this one from the steering column . Just not sure about the two studs holding it on ,I think they have to be drilled out.
