Broken glove box pully...thingy bob
J7USS Oct 7, 2007
  1. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    My glove box wont open due to some heavy handed git (....which was Me).. tried to pull it open whilst it was locked, It just pulls freely now but I had to use a Screwdriver to get into it this morning.
    Any ideas as to whether its fixable or do I need a new mechanism or something??
    Cheers Folks...
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Depends what you've broken. You can get the latch mechanism from your Audi dealer for around £20, they usually keep them in stock. Mine just wouldn't open at all and I had to force it breaking the latch.
    While you're at it squirt some silicon spray on the hinge damper (on the side nearest the passenger door), as these seize up and then you end up breaking the hinge by forcing the door down, which requires a whole new glovebox at £400 a pop (nice one Audi glovebox designer!).
    I just repaired mine with a metal strip & araldite.
  3. J7USS
    3,737
    77
    cheers andy, im going to take the Box out and strip it down so I can see behind the latch to see whats what. There is Noooooo way id ever pay that amount for a glovebox, thats taking the **** aint it...
  4. jase0851
    jase0851 Member
    789
    ive seen glovebox,s go for 10-20 quid on ebay.de juss mine is a pain in the **** to open real stiff
  5. AndyMac
    9,832
    46
    That'll be the damper seizing up
  6. tjm69
    tjm69 Member
    80
    damn my glovebox is stiff to open aswell, thought that was "normal".
    will try the silicon spray.
  7. jase0851
    jase0851 Member
    789
    ill spray some silicone on it andy when i can get hold of some
  8. J7USS
    3,737
    77
    Andy You was right, £19 from Audi for Comlete new catch. Job done!!!
    Now I have the seized problem, So im going to spray it so it drops Smooth again!!
  9. AndyMac
    9,832
    46
    I learned the hard way and managed to break the plastic hinge trying to pry it open. Managed to repair it with some old school meccano painted black, as the hinge is integral to the whole glovebox and can't be replaced without replacing the whole thing. So like many things - if it's stiff be very gentle with it and use some lubricant!
  10. bonerp
    bonerp Member
    180
    now my pulley thing has broke - who said Audis had german build quality?! Piece of cr4p. Really disappointed with this and other issues coming from such a marque.
  11. s8craig
    1,753
    56
    A new glovebox is around £150 less discount,be careful when buying a glovebox from ebay.de, they will probably be a left hooker.
  12. quattrojames
    14,060
    583
    Holy thread revival!
    So after all the TLC I have shown my glovebox this week it repays me with the catch breaking! Its too late and too dark to look now, but the catch just pulls as if the glovebox is locked. Hopefully I will be able to get into it tomorrow and examine more.
    @ J7 - is a new catch a simple fit?
  13. J7USS
    3,737
    77
    lol sorry james, had to laugh there.You treat your motor with upmost respect and tender care, a nice tidy Hinge repair and then it repays you by the catch snapping.What is wrong with these bloody glove boxes....
    anyway mate,yes easy fit, take you 10mins. You just have to replace your lock mechanism around to the new one and slot it in, screw tight = job done.
    I had to use 2 screwdrivers IIRC to get into my glove box.
    good luck mate!!
  14. quattrojames
    14,060
    583
    Lol I'm glad someone found it amusing! I woke up feeling slightly less pi$$ed than when it broke lol! In all seriousness it does my head in though! As you say we look after our cars and it's one thing after another .... I know people who don't give a rat ass for their cars and they still carry on fine!
    I managed to open the glovebox eventually, luckily the two hinge pins underneath (replaced 24 hours earlier lol) came out ok so I could get the lid off. I still had the snap the handle bit by bit with pliers and pull it out though:
    Once it's out its easy to see how it works. looks like a simple swap - Poole Audi on Monday! I suppose it's just coincidence as I cant see how my hinge repair would have affected it.
  15. crofty90
    crofty90 New Member
    does anyone know how to get the lock back out without breaking it??? cheers
  16. Toff
    Toff Diddly sQuattro
    Hi,
    Does anybody know if it's possible to get the leaver out *without* snapping it?
    I have read on other forums that this has been done (so the push-rod glued-back on with epoxy) but there are no clues as to how it can be done.
    Is it a simple case of breaking the existing one (getting it out) and spending £20 on the replacement part from Audi?
    Toff.
  17. quattrojames
    14,060
    583
    I've replied to your PM Toff - I tried for ages with no success and ended up taking the hinge pins out from underneath.
  18. Toff
    Hi,
    If you find that you pull the lever on your glovebox one day and nothing happens, this means the plastic arm has snapped-off the back of the lever. Whilst my car has covered 145k miles and the arm on mine has only just snapped, IMHO this is a poor piece of design by Audi (or whoever they commissioned to make the glove boxes). It is possible Audi have engineered this plastic arm as a point of weakness, but as that should be the job of the lock shroud, I personally think there's no reason it can't be made stronger.
    This guide will help you permanently repair the arm without the need to break the lever facia in the process. It is a lot of effort considering you can buy replacement parts for £20 from Audi, however, this repair should fix the lever permanently whereas the replacement Audi part may break again in the future. This guide will also help you fit the replacement part from Audi if you'd prefer to go down that route.
    PLEASE NOTE: This issue tackled in this guide is not related in any way to the broken hinge / damper issue (whereby the glovebox takes ages to fall open / the glovebox falls-open freely). There are plenty of other posts regarding this hinge / damper issue - please do not discuss this topic on this post, thanks.
    DOWNLOAD THIS GUIDE AS A PDF:
    Click HERE to download this guide in PDF format (useful for printing out to refer to whilst working in your car).
    DISCLAIMER: You follow this guide at your own risk! There is a chance you may snap, scratch or break things as a result of following this guide, I accept no responsibility!
    WHAT YOU'LL NEED:
    • A screwdriver with a star shaped bit (I'm unsure what size, sorry)
    • An 8mm socket bit for removing the bolts that hold the glovebox in place
    • A Philips screwdriver with a very small head
    • A multi-tool (i.e. a Leatherman) or a small file
    • A medium sized metal file
    • Tin shears (metal cutters)
    • A pair of pliers
    • A small or medium sized hammer
    • A fine point permanent marker (CD / DVD marker pen)
    • A small (3mm) rivet
    • A hand-operated rivet gun
    • 3mm metal drill
    • A drill (battery operated or mains, preferably with speed control for delicate work)
    • A small strip of aluminium bar (about 2mm thick) - aviable from larger DIY stores (such as Homebase & B&Q)
    • 2-part Epoxy resin glue (such as Araldite)
    • Protective gloves if you are health & safety conscious!
    • Kitchen roll / paper towels (to deal with the mess the glue makes!)
    • You may also want to purchase the glovebox to aircon connection pipe and valve (they cost about £25 all-in and are worth doing whilst you have the glovebox out! I don't have part numbers, sorry).
    POSSIBLE SHORTCUT
    You have to remove the glovebox to gain easy access to the hex screw on the right-hand side of the glovebox (on UK models at least). You could try using a right-angle adapter or bendy screwdriver extender to remove the hex screw whilst the glovebox is in place (you can skip STEP 1 if you are able to do this!)
    STEP 1: REMOVING THE GLOVEBOX
    1. Go-round to the passenger side of the car, use your key to pop-off the end panel.
    2. Using your key (or a screwdriver), press the end of the catch to open the glovebox (this moves the latches that the glove box lever is supposed to operate).
    3. Open the glovebox and use the 8mm socket bit (or socket set) to undo all 5 bolts that hold the glovebox on (three on the top row as pictured and two on the left & right accessed from below the glovebox).
    4. Lower the dashboard carefully (raise your legs to support it)
    5. Whilst supporting the glove box, undo the camel-yellow coloured connector at the back of the glove box's built-in foot well cover
    STEP 2: REMOVING THE BROKEN GLOVEBOX LEVER
    Now you have removed the glovebox, take it inside and rest it on something soft (like a carpet / beanbag) so it doesn't get scratched.
    1. Turn the glovebox on it's side so the lever is at the top. With the glovebox open, look along the edge of the lid and you will see a recessed hex screw; undo this screw.
    2. Now the hex screw has been removed, you can remove the lever. There should be no need to use screwdrivers to get the lever out. Use your finger to press-in the black plastic latch (on the end of the glovebox lid) to release the pressure on the lever. Now pull the lever open and rock it from side to side, whilst pulling it towards you. It's quite tough, so give it a good tug if it won't come loose. It should eventually come loose. Look-out for a small piece of plastic falling out as you remove the lever assembly (do not throw this away!)
    3. Looking at the back of the lever assembly, you can see where the plastic arm has snapped-off (I have enlarged the area in the photo below)
    4. The front part of the lever assembly is held to the back by a pivot pin. You need to carefully punch this out using a screwdriver with a small head. Make sure you place something underneath that you don't mind getting marked (I used a mallet)
    NB: One end of the pivot pin is larger than the other (and knurled - to stop it coming loose). Make sure you punch the pin on the smaller bevelled end, otherwise you will split the plastic!
    5. Once you've punched the pin out a little way, use some pliers to pull the pin out all the way (don't worry, the spring won't fly off too far and it's easy to put back in place).
    STEP 3: REPAIRING THE BROKEN GLOVEBOX LEVER
    In the photo below, you can now clearly see where the plastic arm has broken off from. There isn't much material or space to work with, so a neat little fix is required using a strip of aluminium, epoxy glue and a rivet.
    1. Hold the broken arm back in it's original place and offer-up a small strip of aluminium, pressing it right-up against the back of the lever (its very important that you get a tight fit). Hopefully your plastic arm will have split in the same place as mine - leaving enough material to work with.
    2. Draw round whole arm (regardless of where it's snapped); we're going to make a copy of it in aluminium!
    3. Using appropriate metal working tools, cut-out & shape the aluminium bar until its a perfect copy of the whole plastic arm.
    4. Take the aluminium copy of the arm and drill a hole in it at least 5mm away from the point where it's snapped (but not too close to the tip, you don't want to split the plastic).
    5. Having drilled the first hole, you now need to mark the hole where the pivot pin goes through.
    6. As accurately as possible, drill a hole where you previously marked. Offer the drilled aluminium arm upto the lever and make sure the pivot pin slides in (it should be reasonably snug fit, not really tight).
    Also make sure the other hole still lines-up to to the hole you drilled in the snapped-off piece of the plastic arm. Ensure the 3mm rivet can fit through both the aluminium and plastic arm when pressed together.
    NB: Its essential you do the above before you attempt to glue things together! Carefully wiggle / oscillate the drill bit whilst drilling to widen the holes if necessary.
    7. Using the edge of a medium metal file, deeply scratch the two surfaces of the aluminium & plastic arms (just the surfaces that are going to face each other). This is to give the epoxy resin glue something to bond to. Make sure you also scratch-up the lower part of the broken plastic arm (the part that's still attached to the lever).
    NB: The aluminium arm needs to go on the inside of the plastic arm; near where the spring is situated - refer to the photos further down.
    NB: You have to be quick with the next few steps because some epoxy resins start to harden after 90 seconds! (even quicker if it's a very hot day!)
    8. Mix-up some epoxy resin glue and smother some onto the rough side of the aluminium arm (be liberal - it won't be on show, so it doesn't matter if it gets a bit messy!)
    9. Press the broken plastic arm onto the glue-coated aluminium arm & push the 3mm rivet through the hole that goes through the two arms (ensuring you feed it though the plastic arm first) and pop the rivet using a rivet gun.
    NB: The flattest part of the rivet must be on the plastic side of the arm as clearance in the lever assembly is tight (this will become apparent further on).
    10. Push the glued & riveted arm assembly onto the rest of the plastic arm (the broken plastic bit on the lever).
    11. Push the pivot pin through the holes on the lever and through the aluminium arm (this just ensures everything is lined-up properly, we'll be connecting it to rest of the lever assembly later).
    Ensure that the aluminium arm is pressed-up against the broken plastic arm along it's whole length and that there is plenty of glue in the crack where the plastic arm snapped apart.
    General photos for steps 9, 10 & 11:
    NB: At this stage, you should leave the repaired arm for a couple of hours to set. Very gently turn the pivot pin after about 15 minutes to ensure it doesn't get glued in-place (pinch the aluminium & plastic arms together whilst doing this to prevent them separating). Sometimes epoxy resin can take quite a while to set, so ensure the arm is solidly set before proceeding to the next step.
    STEP 4: REASSEMBLING THE LEVER ASSEMBLY
    Making sure the the epoxy resin has been given enough time to set properly, you can now prepare the rest of the lever assembly to accept the repaired arm.
    1. Remove the pivot pin that was temporarily installed (to hold the arm whilst the glue was setting).
    2. Because the repaired arm is much thicker (and stronger) than the original plastic arm, the aperture on the black part of the lever assembly needs to be significantly widened to accommodate it.
    I used my drill and the small file on my Leatherman multi-tool to achieve this. I also filed both sides of the rivet (on the repaired arm) a bit flatter to reduce it's profile. It will take a while to get it to fit, you just have to keep filing away!
    3. Ensuring the little black spring is in the correct position, press the two halves of the lever assembly together and insert the pivot pin (smallest-end first of course!) You will have to use a hammer & small screwdriver to tap it fully into place.
    Ensure that the lever assembly can be pivoted back & forth properly (it should be sprung-loaded) you will have to do some more filing if not! This is what the end result should look like:
    STEP 5: RE-FITTING THE LEVER ASSEMBLY
    Now you have repaired the lever assembly, it's time to re-fit it to the glove box.
    1. Because the repaired arm is wider than the original plastic arm, it will be a tight fit in the receptacle pictured below. This will result in a sticky action when you release the lever (it will pull out OK, but won't spring back).
    To resolve this, you need to file away the receptacle and surrounding plastics as pictured below; ensure you finish off with a smooth file to reduce friction.
    NB: I used my metal file to reduce the thickness of the aluminium side of the repaired arm (by about .5mm) to ensure the arm fitted into the receptacle without sticking.
    2. Test-fit the lever assembly by pushing it back into the glovebox lid (don't screw it back in place until you're sure the arm fits in the receptacle properly). Keep filing away until the lever opens and closes smoothly.
    3. Once you're happy with the fit, you can replace the hex screw in the side of the glovebox lid to secure the lever mechanism.
    STEP 6: RE-FITTING THE GLOVE BOX
    Now you have repaired the lever assembly and you're happy with it's operation; it's time to re-fit it to the glove box.
    1. Simply bolt the glovebox back into place and re-attach the side panel (basically, repeat step one in reverse!)
    If you've found this guide useful, please don't forget to click on the REP / THANKS button (bottom left hand corner of this post) to show your appreciation!
    Let me know if you've got any questions.
    Al.
    Mothy69 likes this.
  19. quattrojames
    14,060
    583
    Nice guide! I'm impressed by the little cheat to get the glovebox lid down if the catch is broken, nice work!
    In honesty, I'm not sure I would worry too much about re-enforcing it like that when the replacement catch is only £20 or so, but I'm perhaps just lazy!
  20. Toff
    Thanks. Well, at least the chances of it breaking again are slim to none, unlike the replacement part! But you are right, yo do have to weigh-up the cost of £20 vs the time it takes to do the fix. I love fixing stuff though :)
    Al.
  21. reynoldsl
    reynoldsl New Member
    Thanx Al, I managed to get the glove box open by removing the panel as per your guide. I decided that there's no need for me to have the catch fixed. I'll continue to open it with the side panel removed. (lazy me!)..Lawrence
  22. Chrisavant
    Chrisavant Member
    42
    Many thanks Toff / Al. If I hadn't had your wonderful guide, I was going to attempt to separate the inner and outer leaves of the glovebox lid! Now I see it's actually much less risky and more satisfying!
  23. arch-stanton
    arch-stanton Member
    42
    Great guide.. thanks! :thumbsup:
  24. Jules
    Jules Member
    130
    Has anyone got a picture of the damper in place on the glovebox as i think mine is missing, when you open the glovebox it just drops to the lowest position i am sure the wife will break the lugs on the glovebox else
  25. quattrojames
    14,060
    583
  26. KevK
    KevK New Member
    Fantastic guide by Toff. Now I feel confident about trying this.
  27. vixmix
    vixmix New Member
    Just done this. Replaced broken damper and bought a replacement lever from Audi (the old one lasted 10 years so with careful handling I think the replacement should last at least as long).
    I took the lock out of the broken lever and popped it in the new lock. NOTE: Remember and hold the lock barrel securely as you pop it out the old lever because there are TINY springs which work the lock. Keep a hold of the barrel and slide it straight into the new lever - ensuring the orientation is correct (use pics above to remind you) and push to locate it within the lever. Worked a treat!
    Many many thanks for this VERY useful guide.
    Vix
  28. mo1976
    mo1976 New Member
    NICE GUIDE, IT WAS EXTREMELY EASY TO FOLLOW AND I DID REPAIR ON MY A4 IN NO TIME. THANK YOU VERY MUCH FOR PUTTING IT TOGETHER. :)
  29. Grifter1
    Grifter1 New Member
    Hi
    Fab post - can anyone help me further. Glove box has no issues with catches and looks like it has been replaced based on the marks around the hinge pins. When I lock the car there's an awful squeal from the glove box. When I remove the small inspection plate cover from the inside of the glove box lid behind the lock there is a connector (a plastic rod with a connector at the end) that's not connected. I cannot work out what it should be connected to, I can't find any broken bits. Could someone help or even take a photo of theirs so I can work out what's missing/broken? Many thanks.
  30. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,249
    192
    Sounds like you have the electric locking glove box. Do you have wires running through the hinges?
  31. Grifter1
    Grifter1 New Member
    Yep - Its linked to the central locking. I'm assuming as its a convertible the glove box locks when you lock the car - well when its working!
    Notice you also fitted cruise control on yours - something I want to do and is on my list - any good threads on that?
    Many thanks
  32. AudiLeon
    2,249
    192
    Loads of info on it bud. Check you have the correct SCCM that allows dis.
    Then it's as simple as fitting the correct SCCM and stalk or just the stalk and telling your engine you have cruise via vcds.
  33. Grifter1
    Grifter1 New Member
    Ok cheers - any advice on the glovebox? - soz to be a pain, just cannot work glovebox out so need a reference point!
  34. AudiLeon
    2,249
    192
    No idea sorry.
  35. Pedroloco
    Pedroloco New Member
    10
    AMEN TOFF YOU ARE A LEGEND!
    Did your walk through 6 months back and been perfect ever since.
    Hats off for think out side of the box and coming up with a well engineered and described solution
  36. erezgt
    erezgt New Member
    hi everybody,
    first i wanna say thanks for the tutorial, it helped me a lot,
    i fixed to pully and than i realised the lockers on both sides doesn't pop out automatically (they supposed no?)
    is there anybody who can help me with this ? i'm so pissed .. i worked so hard on the lock to find it worthless :audibash:
    THANKS !!
  37. Terry Smith
    Terry Smith New Member
    Great guide thanks :D.
    Saved me breaking the glove box and then saved me paying out for a replacement part. Instead of attaching an aluminium plate (which looks the most professional way), I took a slight shortcut and cut two strengthening pieces out of a plastic drinks bottle and super glued them either side of the broken plastic arm. Looks like it will do the job, although it does add some friction putting something outside as well as inside the arm. On the plus side it is easy to cut the plastic and no filing is needed. I used the top of the superglue pot to press the plastic bottle pieces onto the arm to avoid getting my fingers stuck!
  38. CULNARA
    CULNARA New Member
    9
    Excellent step by step instructions - I love bodging stuff LOL
  39. Terry Smith
    Update: the superglue and plastic from a drinks bottle shortcut alternative failed - superglue was not the right choice :confusion:
    A second attempt using Araldite instead looks to be holding well (fingers crossed!)
  40. tre_audi
    tre_audi New Member
    10
    Somewhat of a different fix, but for anyone looking for a video of the glove box removal, you'll find a clear one here.
    AUDI A4 glove box removal and hinge repair DIY
