Broken electric window
dieselfitter251 Dec 7, 2008
  1. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    Just investigated why my drivers window doesn't move any more...
    ..The tension cable has broken... looks more like rusted through, there's no sign of corrosion on the inside of the door so it must just be 233k worth of moisture.
    Has anybody attempted to fix this type of porblem. Looks like an absolute pain in the ****...
    I'm considering three fixes.
    1)Do nothing
    2)Revert to a manual winder - 'tho I don't think the B5 ever even had a manual unit on the front.
    3)Get a new door. Which could be the best option as this door has a good bit of rust on it....
    Any input chaps?:uhm:
  2. Siena
    Siena Active Member
    2,626
    I might have my old pre-facelift front doors, doesn't help your window issue though.
  3. dieselfitter251
    1,120
  4. Siena
    Siena Active Member
    2,626
    It is fiddly, yes.
    I've never had to repair one in a B5, but from my Audi 80 / 90 / 100 / Coupe / S2 days, it sucked big hairy balls trying to replace the cable.
    I just fitted working used ones, and they worked fine.
  5. stapo69
    stapo69 All hail the mighty quattro!
    969
    When my cable broke, rusted through like yours, on my 1998 s4 you couldn't get just the cable, had to buy a whole window mechanism because the plastic parts are all sealed, think the motor and electrics all got swapped over, still cost me around 90 odd quid though. Not too bad a job though, once the door card is off the whole guts of the doors come out after undoing 4 big bolts, it's all on one big frame including the window frame, just leaves the painted door skin, once this is all of the car it's easy enough to get to the parts and swap what you need.
  6. docurley
    4,073
    88
    well if it helps i have a whole window frame and motor if any good to you for £40.
  7. Siena
    Siena Active Member
    2,626
    ^^^ Way to go, you can't beat a bolt-in solution.
    Cable repairs are messy, and mostly unsuccessful long term.
  8. stapo69
    969
    Sounds like a bargain!
  9. dieselfitter251
    1,120
    Hey man, great news.... I'll PM you...
