Broken down; clutch pedal?
carbster09 Jan 23, 2008
  1. carbster09
    carbster09 New Member
    21
    While driving in town my clutch pedal went to the floorboard. I noted a little piece of broken plastic and actually felt it break! I was told it was a part of the linkage and need a whole pedal assy; ~ £120 total. Does this make sense? Is this common? I bet it would be an easy fix for me; however I had the car towed as I needed to get to a meeting!
    carbster09:faint:
  2. nky_84
    nky_84 6th Gear
    473
    13
    do a search
  3. Tastyterrier
    Tastyterrier Monkey Trainer
    343
    It's common, a fragile weld joint breaks. £120 sounds about right
  4. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    495
    61
    mine went to the floor the other day, pulled it back up with my hand and when i push it back down theres a bit of pressure but not much then it hits the floor again....think mines either master or slave cylinder on the clutch
  5. rickparmar
    rickparmar va va voom
    2,272
    slave clylinder most likely,
    i just had my master cylinder replaced, didnt solve it, so it was the slave cylinder, so had to get a new slave, clutch kit and white the gearbox was open the flyweek got replace,
    paid alll togeth inc labour and parts, £900, it does hurt lol
  6. rickparmar
    2,272
    have a look here
    http://www.tt-forum.co.uk/
    comon problem on the TT, shows you somwhere how to fix it
  7. jesters3
    jesters3 Active Member VCDS Map User
    1,516
  8. c16wko
    c16wko Member
    71
    sounds to me like clutch master cylinder?
    apparently the clips are prone to snapping?
    got a new one from gsf for £35
