Brighter main beams
JaminBen Mar 28, 2005
  1. JaminBen
    JaminBen Member
    532
    Has anyone changed their main beam bulbs for something brighter / whiter? I've searched the forum and haven't come up with anything...
    Going from the (xenon) low beam to (halogen) high beam doesn't seem to yield much gain in terms of reach / brightness. Any suggestions?
    TIA
    -Ben
  2. h5djr
    9,466
    1,773
    I don't have Xenon dip beam, but I have chnaged both my dip and main beam bulbs to Philips Vision Plus which are supposed to give 50% more light than a ordinary halogen bulb.
    I find them a definite improvement over the ordinary bulbs.
  3. IanMcA3
    IanMcA3 Member
    59
    I'm running Xenon's on mine, for the main beam I use Philips Sportzblue bulbs in the H7 fitment
    They are rated at 80w so strictly not legal, but hey, full beam shouldn't be used to dazzle other road users!
    Also noticed that the H7's I took out of the car were only rated at 55w, now I know for a fact that other cars with a H4 bulb, and 2 filaments in the one unit, were rated at 55w (dip) / 60w (full) so the choice of bulb by Audi does seem to be a bit off!
  4. Mark_N
    Mark_N Member
    250
    I have the xenons too and the side lights/full beam are very yellow in comparison.
    There's a fairly white sidelight/beam available and lots of guys over on uk-mkivs.net have it.
    I *think* they're called PIAA or something like that.
  5. [ QUOTE ]
    [/ QUOTE ]
    I dont have xenons (unfortunately) but I have replaced the dipped beam with some PIAA Xtreme White H7's, which have a much sharper, crisp white light,though the should at £65 a time!! The side lights have been replaced by the Phillips Blue Vision bulbs you get free when ordering from PowerBulbs. Changing the sidelight bulbs makes all the difference.
  6. marriedblonde
    marriedblonde Active Member
    4,375
    10
    Can you change them on the Xenon equip'd cars? It would be nice to get rid of the yellowish side lights.
    I wanted to change the indicator blbs with some silver ones to get rid of the orange and there's no room around them...
    J.
  7. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,730
    1,566
    I went out and bought four PIAA bulbs, expensive but well worth it, very close to HID out put and on main beam as well.
  8. As people have said the Dipped and Main beam bulbs (both h7) are very easy to change. The side lights are not so easy. The driver side one is the easiest to do out of the 2. You need a long thin set of pliers. They just need pulling back and they should pop out.Once out it is very easy to change them.
    **TIP**
    I found when changing the side light on the passenger side it was easier to take out the main beam bulb first so you can see what your holding on too with the pliers.
    hope this helps
  9. [ QUOTE ]
    [ QUOTE ]
    hope this helps
    [/ QUOTE ]
    It sure does!
    Thanks, everyone, for your input. Now I just have to make up my mind as to which bulbs to purchase.
    Thanks again,
    -Ben
    [/ QUOTE ]
    It depends on what you want from the bulb. Do you want a HID look, clearer light output or a combination of the 2?
    IMO/experience the Osrams and Phillips bulbs don't change the look all that much, when looking at the lens, also on modern cars the light output is not that much better than the standard bulbs. You need a bulb that has a fairly high output with a slight blue tint on the glass (not too much other wise the light output will be restricted)
    I personally think that the PIAA xtreme whites give the best results. Just a shame about the price!
  10. Amchlolor
    Amchlolor Active Member
    5,604
    Going from memory,the way autoexpress rate the bulbs is by measuring the distance they light up a kerb.
    The Osrams lit up 58% more of the kerb than standard.
    That's the kind of thing I'm after.
    I don't necessarily want brighter.
    I just want the cut-off to be less abrupt.
    Am I making sense ? /ubbthreads/images/graemlins/confused.gif
  11. Amchlolor
    5,604
  12. steeve
    2,730
    1,566
    Over the years I have tried most of them, always come back to the PIAA bulbs, huge improvement over what is fitted as standard. It does work out expensive to fit all four (they are all H7's) but I need to drive down small dark country lanes and find it well worth the money. They did have a reputation for early failure but I have NEVER had one go. Perhaps shouldnt have said that. They are easy to change, note that the bulb clips in and out follow the instructions in your handbook...... /ubbthreads/images/graemlins/dancing.gif /ubbthreads/images/graemlins/dancing.gif /ubbthreads/images/graemlins/yes.gif
  13. imported_migzy
    imported_migzy Guest
    can't see the 10% refund and free side bulbs on the site, can you point me in the right direction.
    thanks
    migzy
  14. imported_migzy
    sorry, just spotted it, goign blind with my old age.
    migzy
  15. Amchlolor
    5,604
    Just as well you're ordering brighter bulbs then.... /ubbthreads/images/graemlins/laugh_roll.gif
  16. StephaneS
    StephaneS Member
    379
    had changed to the osram on mine (bought from powerbulbs as well with the free bleue vision philips lights that I could not be bothered to fit - I still have them actually) and did not find much difference (didnot have xenons). Only a little bit whiter but the light does not go further than standard. /ubbthreads/images/graemlins/confused.gif
    I think it's to do with the design of the car headlamps really. Even our polo does light up the road better!! /ubbthreads/images/graemlins/blush.gif
  17. Amchlolor
    5,604
    I misunderstood the way the bulbs are tested.
    The Osrams did not light up 58% more road,as such.
    They were found to be 58% brighter than standard at a distance of 50 metres.
    Still,should be a useful improvement and only £45 spent,after all.
  18. Mark_N
    Mark_N Member
    250
    They're probably from Vagparts..
    I had them on a Golf and they're good - and bright but not a patch on OEM xenons.
  19. JaminBen
    JaminBen Member
    532
    [ QUOTE ]
    although they aren't european branded hella/philip (£240 if you want hella), they still provide you with true xenon brightness
    [/ QUOTE ]
    Are these for main (high) beams?
    When I searched this forum regarding bulbs, I came across an interesting thread, that mentioned the fact that xenons fitted in non-projector-style lenses don't really do much in terms of reach...
  20. JaminBen
    JaminBen Member
    532
