Briaded lines, fluid change, s3 312mm set up
vince, A3 turbo
Alright guys
I'm upgrading to a s3 break set up this week with braided lines, I want to change the
break fluid rather then topping it up after I've done the lines as it's old so I'm guessing
new will be better and boil at a Higher temp??
I Was wondering if any one knew how much fluid I will need and is there a certain one to get or is it just dot 4?
Vince
Motul RBF 600 or 660 if you want something a little special else just use std DOT 4... 5.1 isn't worth the time of day compared to RBF 660 imo...
If doing a full replace then 2 x 500ml bottles should do it but I have sometimes had to top up with a third...
