brembo brakes
campbell Jun 15, 2010
  1. campbell
    campbell Member
    726
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Personally if the brakes you have are doing a good enough job for the type of driving you do I wouldn't bother wasting your money. £600 will get you a full springs/shocks kit, coilovers or some new wheels. Just my opinion
  3. <tuffty/>
    21,873
    4,199
    Those will need brackets (and bolts... not normal bolts either, must be right hardness), they look like Brembo Jnr calipers (same as Ibiza Cupra R) so Badger 5 brackets should fit else you will need to get some from Brembo (if you can of course, should be part of the GT kit) or SEAT which won't be cheap IIRC...
    The discs will prob be LCR ones so 323mmx28mm, cheap enough to buy but looking at the colour of the calipers they have had a hard life so may need new piston dust covers...
    You could just build a kit from new stuff, these calipers are the same as the ones I have...
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260603789634
    Can be made to use the LCR discs which can be bought quite cheaply or 2-piece 330mm like mine... for what its worth I was playing with the g-force gauge on my Liquid Gauge and pulled 1.05g on braking....
  4. jojo
    28,997
    3,649
    I think £650 is top money, plus the calipers need a repaint, look elsewhere.
  5. campbell
    campbell Member
    726
    So they wouldnt fit the black diamond discs i have already on? i do think there top money at that but was just thinking of putting a low bid in and see what happens!
    £600 would get me new alloys or suspension, i have forgot to update my profile, all my suspension is new-B8 dampers, springs, R32 ARBs!
  6. badger5
    9,598
    2,060
    unless your existing disks are 323x28 then no.. they wont just fit on.
    312mm on your S3 as std
  7. <tuffty/>
    21,873
    4,199
    As Bill said... std S3 discs are 312x25mm... not wide enough for the Brembo caliper
  8. campbell
    campbell Member
    726
    i dont think im going to bother on these brakes, sounds too much money. HOw would they compare with the black diamond discs and DS2500 pads out of curiousity?
    cheers
  9. finesse
    finesse Active Member
    2,805
    Look elsewhere
  10. 123holah
    123holah Member
    56
    least he will take is £580 i already tried!
  11. jojo
    28,997
    3,649
    But what would one pay for a set of these on the used market? I've looked around and seen price variations between £500-750 for used Brembo's.
