For Sale Brembo 6 pot calipers (supplied in your colour of choice)
Craig Cull Aug 2, 2014
  1. Craig Cull
    Craig Cull Well-Known Member
    2,451
    1,409
    Here I have for sale. A pair of Brembo 6 pot 18z calipers in red.
    These calipers have been tested, powder coated and re sealed if required.
    I currently have 2 pairs in stock and more coming next week.
    All will be in red although other colours are available on request.
    Calipers £530 posted!
    If you have an Audi A4 B7,6 or 5, I can do the full conversion with pagid pads, braided lines and drilled or drilled and grooved discs for £800. Also available on request.
    Alex C likes this.
  2. Craig Cull
    2,451
    1,409
    Bump
  3. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,079
    768
    can you get 4 pot 996 rears Craig?
    Trups
  4. Chrislich
    Chrislich Member
    44
    If only my tax and insurance weren't coming up. I take it these need a bracket to fit b7
  5. lowlife89
    lowlife89 Member
    193
    22
    Anything for the rear?
  6. Craig Cull
    2,451
    1,409
    I will give my supplier a call mate and let you know
    t8ups likes this.
  7. Craig Cull
    2,451
    1,409
    No bracket mate, just the correct discs and they are more or less a direct fit
  8. Craig Cull
    2,451
    1,409
    I'm working on the rears mate, Issue you have is the handbrake, would need a trailing caliper for the handbrake aswell as a seperate caliper. I'll let you know how I get on.
  9. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    441
    Interested PM me would like to discuss??
  10. Craig Cull
    2,451
    1,409
    Your inbox is full mate. As bad as me lol! Give me a pm when ur free 😃
  11. Craig Cull
    2,451
    1,409
    Or bell me after 5 on 07715407915
  12. thetrashcanman
    thetrashcanman Member
    81
    Don't suppose you can do discs/kit for an 8P s3 mate? I have the 8 pot brembos from an r8 that i'd quite like to fit on mine, but need some discs first.
  13. Craig Cull
    2,451
    1,409
    It's not something we've tested to be honest mate. All of our testing has been mainly based around the A4 B7.
  14. If you have R8 calipers you will be needing brackets as the R8s bolt straight on to the R8 hub carrier
  15. Craig Cull
    2,451
    1,409
    More in stock!!
  16. Craig Cull
    2,451
    1,409
    Can have a pair by the end of the month mate, £400 fully refurbished in your colour of choice :)
  17. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Hi Craig,
    I am interested in a set of these - may I ask where you are getting them from?
    Thanks,
  18. Craig Cull
    2,451
    1,409
    I just have a supplier who buys the calipers and refurbishes them to be totally honest mate. I buy them in bulk so I can supply them at a good price for fellow enthusiasts. Cuts out the hassle of having to find a decent pair and then send them off like I did. Also have a good connection for the centre bores on the discs.
    It's just nice to have all your eggs in one basket :)
  19. jbcalvin
    jbcalvin Member
    691
    21
    Will these fit behind a standard 16"wheel? I run my old 16's with winters during the cold season up here in Scotland….
  20. Craig Cull
    2,451
    1,409
    No chance mate, they are huge!
    They will fit behind 18's but nothing smaller I'm afraid.
  21. jbcalvin
    jbcalvin Member
    691
    21
    That's me out then..... Cheers anyway
  22. joedredd
    joedredd 2006 A6 S line 3.0tdi Quattro Avant VCDS Map User
    200
    27
    Would love a set of these for my A6 C6
  23. Craig Cull
    2,451
    1,409
    Bump
  24. t8ups
    2,079
    768
    Hi Craig.
    Would want them gloss black, can you put the brembo logo on them?
    And also, how sure are you that they will be 996 rears? As the boxster ones have the same part number and these won't work.
    If they are 996 and you can gruntee they are I'm happy to have them.
    Trups
  25. Craig Cull
    2,451
    1,409
    Hi mate, I'm basically relying on my supplier to be correct in what he says. Would R8 rears be any use to you?
    Yes the brembo logo will be put on in your colour of choice also. Send me your number and I'll give you a call this evening mate :)
  26. Ben Hall
    Ben Hall Member
    41
    have Read the comments ah these a direct replacement for the audi s3 brake calliper which has the 345mm disc currently
    many thanks Ben
  27. Craig Cull
    2,451
    1,409
    Afraid not Ben, I've been told the RS3 upgrade is the best upgrade for the S3 cost wise.
  28. Ben Hall
    Ben Hall Member
    41
    Thanks for your time
    Craig Cull likes this.
  29. Ash B
    Ash B Well-Known Member
    5,831
    85
    Craig would you be able to source me RS6 8pot fronts and R8 4pot rears kit please? Be looking on getting some bbk in october :)
    kkp0897 likes this.
  30. Craig Cull
    2,451
    1,409
    I can get the R8 4 pot rears but you will need a trailing caliper for the handbrake. As for the RS6 8pots.... Were trialing the phaeton 8pots on the front. Not sure if the RS6 are a direct fit. RS4 B7's are but not cheap with the 2 piece discs. The 6pot cayenne is the cheapest and best option for the B7. You can also upgrade to 360mm 2 piece discs if required. But unless your going round the nuburgring the ml55 discs are more than adequate.
  31. Craig Cull
    2,451
    1,409
    Bump
  32. t8ups
    2,079
    768
    PM sent about R8 calipers.
  33. Craig Cull
    2,451
    1,409
    Bump
  34. joedredd
    200
    27
    Craig, what can you do for my A6 (as per sig)?
  35. Craig Cull
    2,451
    1,409
    I'll do some research mate and get back to you. Can't see why the A4 set up wouldn't fit, but I'll confirm.
  36. Avant-81
    Avant-81 Member
    43
    What size of discs come with whe kits for a b6
  37. Craig Cull
    2,451
    1,409
    345mm x 32mm discs
  38. joedredd
    200
    27
    Thanks Craig, keep me posted. Keeping fingers crossed ;)
  39. NotNormal
    NotNormal Active Member Team Nano Grey VCDS Map User Audi S3 quattro s tronic
    338
    67
    This is the disc size for @joedredd 's car
    Not sure what offset they are compared to the discs you supply
    I too could be interested in a kit, calipers and brackets + lines (a6 c6 3.0tdi 2009)
    What would I need to order pads for ? (I don't wish to use the paged ones)
    Tom
  40. Craig Cull
    2,451
    1,409
    The calipers will fit the A6, if you wish to supply your own discs and pads, that's fine. I'll just supply the calipers. You shouldn't need brackets as they will bolt straight to the hub. RS4 to brembo braided hoses should be fine.
