breather pipe part problem
fran-s3 May 14, 2008
  1. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Hi Chaps,
    Just thought I'd throw this one out there as my local audi dealer in Northampton are having a few issues locating a part... Have an 01 facelift S3 and part of my breather pipe has split (temp repaired for now).. Popped off 2 hours after my revo remap which has now been turned off until it's fixed...
    Tube is located under the manifold.. An Audi mechanic looked under the bonnet and the part number on it that he wrote down doesn't exist LOL! The closest one was nothing like it, bizzare! It's basically a long tube with a T bracket in the middle of it, may just try and source some piping but the original O/E part would be nice! Anyone else had this dilemma? There currently looking into...
  2. jesters3
    jesters3 Active Member VCDS Map User
    1,516
  3. fran-s3
    1,103
    That looks exactly what I need, Im faxing that over to audi as the schemetatic they had looked nothing like that! THANKS!
    I think the T piece im reffering to is 5, but yes the tip of 9 seems to off plit on mine or 9a... They both seem to connect to 8 which is confusing!
  4. jesters3
    1,516
    Cool hopefully they should sort it for you.
    Yeah the schematic shows the options for various engines, 9a is for a BAM engine 9 is for AGU etc, so gives you the options - get yourself registered on vagcat.com and trawl through there it is useful and has all the part numbers you may need.
  5. fran-s3
    1,103
    Right ordered, my engine code is AMK BUT the dealer said the right breather hose was part no 06A103213AK... BUT the vagcat says the AMK version of the part is 06A103213T.. so no im thinking the dealer has ordered the wrong part! But he was ademate it was correct!
  6. jesters3
    1,516
    Hmm, the part is 9a on both accounts but with different code endings T & AK. Mine was AK for a BAM engine; all I know is that some times they have revisions of the same part sooo the AK could be a later revision than the T.....
    All I would say is that once you get it; do not take it out of the wrapper, get the old one off and then compare and make sure - should take about 5 mins to get it off.
    Oh by the way the clip underneath the manifold is one of those Audi throwaway ones, so have a couple of jubliee 10 clips handy to use at both ends.
  7. fran-s3
    1,103
    Arrr ok that may make sense as yours according to the sheet should of only fitted to AUQ ARX ARY and AUM not your BAM so I'll leave it be then...
    Yes never thought of that could be a revised part! Cool thanks for the advise, will let you know how it goes!
  8. jesters3
    1,516
    Just re-read and the AK is the correct part for your AMK engine.
    (9A)06A103213AK
    breather tube
    / AMK,BAM
    it is the way it is laid out that confuses; the T is for a AUL engine
    (9A)06A103213T
    breather tube
    / AUL
    You have to look at the line colours to match em up :readit:
  9. fran-s3
    1,103
    Arrrrrrrrrrr I got you! How confusing is that, yes so it is right!!!!! That was confusing!!!!
