Breaking facelift Avant 1.8t
olds_kool Nov 5, 2009
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    im breaking a facelift 99 silver avant 1.8t
    most parts available
    please pm for more info
    off the top of my head
    3 spoke wheel (shabby)
    stalks
    instrument cluster (missing lines on dis) with skc
    heater motor
    complete centre console for conversion?
    front armrest in grey cloth x2
    headlining, lights have ambient leds
    door cards, onyx with grey insert and bose grills
    sport seats, electric lumbar/heated (shabby)
    airbag controller 8D0959655J
    door seals/tailgate seal
    front/rear wiper motor
    lock set
    genuine mud flaps
    16" sport alloys
    abs module 8E0614111AB
    facelift scuttle covers
    dbw ecu
    dbw throttle
    load cover
    rear lock plinth (corrosion free)
    facelift grill
    facelift lights
    cd changer
    bose harness/amp/speakers
    brink towbar with electrics
    complete a/c (will remove without undoing any soft joints)
    etc..........
    if it wont fit in a medium size box its collection only !
    facelift rear lights/front lock carrier c/l pump not available
  2. manzi
    manzi Member
    64
    boot come wiht all trim and stuff ;)
    whats the head lamps like, are they pretty stone chipped as like mine are?
  3. Geeman
    Geeman Low Life
    1,318
    Bonnet...?
    Front bumper...?
  4. olds_kool
    1,094
    15
    front bumpers been repaired and resprayed with a can
    bonnet has a 6mm long deep scratch (perfect other than that)
    boot has stone chips along base that've gone rusty so will probably sell lock surround, switches and motor seperatly
    headlamps a bit sorry looking
  5. Geeman
    Geeman Low Life
    1,318
    Get some pics up of the bonnet scratch will ya please... is it bad?
  6. Broken Byzan
    13,237
    465
    I am desperatly wracking my brains as to what i might need....
    Sill trims?
    er
    would love the dash,ECU and TB just as a project maybe...
    Whack me a PM Kev regarding the trims anywho, fanx
  7. manzi
    manzi Member
    64
    was thinking of the fabric part of it :)
    mines bit worn and battered from prev owner tryin to fix boot open mech.
  8. olds_kool
    1,094
    15
    where are you?, you can collect for cheap or £20 posted, pm if interested
  9. manzi
    manzi Member
    64
    will have to be after 15th tho. i'm skint at mo :ermm:
    i'm in Rotherham/Sheffield. anywhere is doable in 1.9tdi :)
  10. GforceA4
    GforceA4 Member
    111
    how much for the central loccking pump and can u get me the number see if it the same as mine and the central console is it a double din unit if so how much and i can collect
    will the mud flaps fit a sallon?
    cheers gareth
  11. Broken Byzan
    13,237
    465
    Errr
  12. GforceA4
    GforceA4 Member
    111
    i should really learn to read lol
    damn it neva mind, my central locking has decided to go pop and it the bloody pump big money
    is the console doubledin?
  13. olds_kool
    1,094
    15
    i can probably fix your pump if its stopped pumping:icon_thumright: facelift 8d0 'e' ?
    console is single din im after double myself
  14. olds_kool
    1,094
    15
    you anywhere near s63 area?, karlos the avant from on here wants some stuff delivering you might be able to sort something along the lines of delivering to him and you get the trim for free?
  15. olds_kool
    1,094
    15
    not forgot about you matey, just looking for something suitable to post them in, will sort it over weekend
  16. Broken Byzan
    13,237
    465
    A bit of cardboard either end and some cling film, with the odd ring of packing tape,lol
  17. GforceA4
    GforceA4 Member
    111
    really much would u charge to fix it mate as that would be great?
    Cheers gareth
  18. olds_kool
    1,094
    15
    £35 if you want to come up here
    just open it up and check impeller is broken up
  19. GforceA4
    GforceA4 Member
    111
    yeah ok that cool do u have the parts to fix it then?
    ur not that far for me anyway.
    Gareth
  20. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    is the ECU DBW not DBC? didn't think DBW came in till 2000.
    will PM you but how much for the ABS controller?
  21. olds_kool
    1,094
    15
    dbw, its got epc light, apu engine rings a bell but would have to check
    pretty sure abs controller wont work on quattro
  22. Broken Byzan
    13,237
    465
    APU is DBW, shame they only came in FWD. Small port heads,IIRC
  23. jcb
    4,132
    13
    ah 2wd.
  24. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    gear linkage price?
  25. olds_kool
    1,094
    15
    it'll be a while before i get around to removing that, need to be able to get it in gear for removing driveshafts
    might be different aswell my tqs has push down reverse selection this hasnt, last 1.8na i broke didnt either
    can you get the bush on its own from audi?
  26. ian52
    1,199
    Have to buy the whole thing from them. It's not a bush that's meant to come out.
  27. Drizz
    Drizz Project Plush
    681
    What door/dash trims does it have?
  28. olds_kool
    1,094
    15
    id say two weeks before i get around to removing engine/box but i reckon rods would be different as reverse selector doesnt use a spring so rods must use different angles or even a different box?
    silvery bronze ones with little triangle details on them, drivers ones got a few dinks and passenger one has a nasty scratch an dent, might be good for experimenting with though, seen some different ideas on audizine fabric, suede, carbon, painted etc.. £28 inc courier if anyone wants them to play around with
  29. Drizz
    Drizz Project Plush
    681
    if they not smooth ill leave them. Cheers
  30. manzi
    manzi Member
    64
    i work near him. really depends what he wants tho.
    i'll pm you near the time about that trim.
  31. PARKER
    PARKER New Member
    29
    fuel pump please, posted.
  32. Intense
    Intense New Member
    17
    How much for the bose setup?
    Dan
  33. Geeman
    Geeman Low Life
    1,318
    Still waiting for pics of the bonnet dude.
    Could do with a few other bits n bobs too... rear drivers-side window triangle trim, centre console button blank, and a few other bits that I can't remember.
    Giles
