Breaking audi S3 8L imola yellow inc VF34
v4rley May 22, 2012
  1. v4rley
    v4rley Member
    54
    As title say, unfortunatly i have had to break my S3 for spares. Reason is because the clutch failed and was the final straw after just recently fitting a new turbo, so i took the decision to break for spares to achieve more fund towards another car. Perhaps another S3 as it has been a fantastic car.
    Car spec: Audi S3 8l APY 85k
    I have spent the past couple of weeks breaking the car so i could access more parts hidden deep behind the engine and dash. Everything to sell from little to larger. Below is a list of oem optional extras and modifications avaliable:
    1. Chrome oem mirrors
    2. Yellow alcantara interior inc door cards
    3. Brembo GT 4 pot front brake calipers including nearly new discs and pads (covered less than 4k)
    4. Forge FMIC with all pipework
    5. Bilstein B14's (kit F4-HE5-8041-HO)
    6. Bosch 550cc injectors
    7. IHI VF34 (less than 4k), jabbasport manifold, downpipe and de-cat
    8. APY engine 85k, with uprated rods, end bearings etc
    Contact me with any part request and offers you have either throught PM, replying or txt 07716087266
    Unfortunatly i do work (9-5 :)) but will try to reply asap
    Parts already sold,
    1. TIP
    2. Exhaust
    3. Passanger door blades
    4. Light switch
    5. Forge DV
    6. Haldex ECU
  2. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Pm'd.
  3. Dani_B19
    9,343
    394
    How mch for the brembos mate?
  4. Gops
    3,198
    666
    How much for both side Indicator lamps?
  5. tonks s3
    tonks s3 Member
    33
    how much for chrome mirrors? cheers :)
  6. scubadriver
    scubadriver New Member
    20
    Do you still have the glove box lid? How much do you want?
  7. v4rley
    v4rley Member
    54
    Pm'd Rear lights sold
  8. Smokey_clark
    Smokey_clark 12th Gear
    210
    How much for the brembos mate? plus can you put me down for FMIC if the provisional seller falls through.
  9. v4rley
    v4rley Member
    54
    Hi Smokey_clarkReally looking for 550 for the brembos, with the discs and pads being virually new and including delivery. Will put you down for seconds on the fmic.
  10. Erf
    Erf Member
    243
    How much for the haldex pre charge pump?
  11. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    Price on mani, downpipe and sports cat. Include postage please cheers.
  12. v4rley
    v4rley Member
    54
    Pm'd
  13. jezzy
    jezzy Member
    768
    fmic how much?
  14. mcpickering
    mcpickering Member
    136
    Couple of little bits needed:Inside the drivers door handle (interior) there is a removable part with a screw at the back and a clip at the front, i need this if possiblePotentially need a full clove box if in good conditionDrivers mirror glass if tinted/heated and good conditionPiano black cubby hole with hinged lid (goes under climate control) if you have one.Let me know which of these bits you have, Thanks.
  15. Ginge
    Ginge It's never fast enough !
    192
    Hello, how much for the rear suspension spring mounts? (If you still have them and they aren't worn through like mine:( ...) Thanks, Tom.
  16. v4rley
    v4rley Member
    54
    Asking for 450 full setup including crash bar
    cheers
  17. v4rley
    v4rley Member
    54
    Hi,
    would like to retain door handle to go with door cards. Glove box in great condition on scratches, only down side is usual problem of broken hinge on n / s hardly noticeable but best to mention, only discovered when i did a usual problem check list, would it still be of interest? Mirror glass not heated :-( and compartment sold. Soz i couldn't be of more help, but let me know if glove box of interest.
  18. v4rley
    v4rley Member
    54
    Mine are pretty worn through too so wouldn't be much use
    cheers
  19. Westy
    Westy Well-Known Member
    17,443
    1,105
    Don't suppose you have wheel spacers?
  20. v4rley
    v4rley Member
    54
    only cheap 5mm ones like they sell in halfords
  21. Where abouts are you located? Is the boot lid in good shape with original paint?
  22. Yohan87
    Yohan87 Guest
    How much for the engine loom (uncut)? Cheers
  23. v4rley
    v4rley Member
    54
    Loom available and not cut, pm sent
  24. smokiedee
    smokiedee Member
    118
    how much u after for the turbo, downpipe, manifold and injectors
  25. Yicker
    Yicker Member
    30
    How much for the rear arb if you still have it?
  26. D11nyd
    D11nyd Member
    32
    Hi do you have the standard headunit avalible and 6disc changer and battery cover?Ifso how much Cheers Danny
  27. v4rley
    v4rley Member
    54
    PM'd
  28. Schlaag
    Schlaag Bwah
    486
    32
    are those 18" genuine audi alloys? if so are they for sale too?
  29. v4rley
    v4rley Member
    54
    Genuine wheels, already sold
  30. hatchs3
    hatchs3 New Member
    9
    Hi, do you still have headlamps and rear tailgate wash-wipe and roof aeriel for sale ? hope so thanks, graeme
