Breaking Audi S3 8L imola yellow inc Brembos, engine 85k,spares everything to go
v4rley Aug 8, 2012
  1. v4rley
    v4rley Member
    54
    As title say, unfortunatly i have had to break my S3 for spares. Reason is because the clutch failed and was the final straw after just recently fitting a new turbo, so i took the decision to break for spares to achieve more fund towards another car. Perhaps another S3 as it has been a fantastic car.
    Car spec: 2000 Audi S3 8l APY (pre-facelift) 85k, I have spent the past couple of weeks breaking the car so i could access more parts hidden deep behind the engine and dash. Everything to sell from little to larger.
    Below is a list of oem optional extras and modifications avaliable:
    Yellow alcantara interior inc door cards
    Brembo GT 4 pot front brake calipers including nearly new discs (323mm)and pads (covered less than 4k) genuine brembo kit, not from cupra R £500
    APY engine 85k, with uprated rods, end bearings etc
    Would like to sell bumper as a whole with grills and all inserts, so would be selling grills seperatly.
    Contact me with any part request and offers you have either throught pm or txt 07716087266, Unfortunatly i do work (9-5) but will try to reply asap
    PARTS ALREADY SOLD,
    TIP
    Exhaust
    All door blades
    Light switch
    Forge DV
    Haldex ECU
    Wheels
    O\S headlight
    Front indicators
    Drivers window regulator
    Piano black ashtray / compartment
    Rear lights
    Rear diff
    FMIC
    drivers A pillar
    Arbs
    N/S driveshaft
    inlet manifold
    throttle body
    over boost pipe
    MAF
    front arch liners
    PVC pipework
    Rear bumper
    Turbo
    rear wiper motor
    aerial fin
    Fuel pump
    suspension
  2. Jpd89
    Jpd89 Member
    118
    How much for the engine?
  3. v4rley
    v4rley Member
    54
    Pm'd
  4. ci-ryder
    ci-ryder Member
    199
    Is that an LCR front splitter and if so how much?
  5. v4rley
    v4rley Member
    54
    yeah is a lcr splitter, was planning to sell with bumper as rivited to it and middle fins but to fit bumper, would remove it for 40 cheers
  6. Nogmeister
    Nogmeister Member
    287
    Alright pal, do you have the dash cup holder at all?
  7. v4rley
    v4rley Member
    54
    Hi mate, unfortunately pre cup holder interior cheers
  8. ci-ryder
    ci-ryder Member
    199
    Thanks for that, I will wait and see as I may end up needing a whole bumper so could end up just going for the lot.
  9. Eddie S3
    Eddie S3 Member
    128
    9
    What engine code is it? If its BAM, how much for the cam chain tensioner?
  10. Eddie S3
    Eddie S3 Member
    128
    9
    Sorry missed where it says APY never mind
  11. Keiran
    Keiran Member
    89
    How much for the front brake carriers mate?
  12. v4rley
    v4rley Member
    54
    Hi,front brake setup is soldcheers
  13. JtotheD
    JtotheD Active Member
    907
    26
    do you have O/S front side indicator ? the one on the front wing? my clip has broken so it doesn't sit flush and moves around!
  14. v4rley
    v4rley Member
    54
    Do you mean the small rectangular one on the side? if so still available
  15. JtotheD
    907
    26
    Yes that one! How does a fiver posted sound? Josh
  16. v4rley
    v4rley Member
    54
    JtotheD: sounds fair, ill pm details.
  17. AVLO
    AVLO Active Member
    295
    52
    hi mate do you have a foot rest (left hand side of clutch?thanks
  18. v4rley
    v4rley Member
    54
    Hi, yes do have that piece. guessing your just after the plastic cover or the entire metal subframe? cheers
  19. AVLO
    AVLO Active Member
    295
    52
    yes mate how much delivered?
  20. v4rley
    v4rley Member
    54
    Something like £12 delievered??
  21. AVLO
    AVLO Active Member
    295
    52
    v4rley pm sent
  22. nathpeach
    nathpeach New Member
    10
    have you sold the engine yet? If not how much are you looking for?
  23. v4rley
    v4rley Member
    54
    A lot of the car has now been sold but still have some big parts remaining:EngineGearboxDoor cards Front slam panelStill many bits left to shift before I have to let her go :-( drop me a txt or pm and ill let you know if still available.Cheers
  24. GlennP83
    GlennP83 Member
    90
    How much for the battery plastic cover and the two little screws? And can u post?
  25. v4rley
    v4rley Member
    54
    Already sold. Cheers
