Breaking A4 B5 Avant (Kermit has croaked)
Alsie Feb 1, 2012
  1. Alsie
    Alsie Member
    133
    In rare Paradise Green...LMK what you want and I'll post a piccy of it....
  2. vroomtshh
    vroomtshh Active Member
    362
    49
    I'm looking for the clip that holds the warning triangle compartment closed?
  3. Alsie
    Alsie Member
    133
    £5 collected or £7.50 posted
  4. colicabcadam
    colicabcadam Guest
    is this a 2.7 v6 by any chance ?
  5. Alsie
    Alsie Member
    133
    no 1.9TDi :)
  6. vroomtshh
    362
    49
    Is that for me?
    Is the warning triangle not in a compartment in the boot?
    There is a knob that turns to keep it closed. On the back of the knob is a diamond shaped clip?
    I have a B6 but my mates B5 is the same so I (stupidly) assumed they all were
  7. Alsie
    Alsie Member
    133
    err in the boot is a compartment door on either side, the warning triangle in behind a door on the O/S/R and this is the catch to release the compartment, let me re attach it to the door....hang on
  8. Alsie
    Alsie Member
    133
    here u go
  9. vroomtshh
    362
    49
    Sorry it must be different. Mine is actually in the tailgate
  10. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    What you see is what the B5s have.
    No idea what you mate have in his B5, unless B6's fit in the B5s.
    All B5s i've seen have the above. Would be interesting to see/know if the B6 fits in the B5.
  11. ScottD3
    15,164
    1,123
    Saloon or avant?
  12. vroomtshh
    362
    49
    Avant
  13. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Are the front wings on an avant the same as a saloon?? If so how much for the nearside F/wing??
  14. Alsie
    Alsie Member
    133
    believe so, £25 plus postage small scuff on it, no dents
  15. colicabcadam
    colicabcadam Guest
    do you have a automatic anti dazzle rear view mirror ?
  16. Alsie
    Alsie Member
    133
    ooh thats a new one on me, how do you tell?
  17. Alsie
    Alsie Member
    133
    Ah i see. my Sport has anti dazzle, kermit has bog standard mirror with a lever on the underside to flick it down
  18. colicabcadam
    colicabcadam Guest
    hmmm, that's all i would have wanted - doh - or do you have a picture of your engine bay by any chance ?
  19. colicabcadam
    colicabcadam Guest
    i basically need 2 (long part) and 3 (battery cover), just not sure if your layout is the same ?
  20. Alsie
    Alsie Member
    133
    those covers were already missing sorry
  21. ScottD3
    15,164
    1,123
    2 and 3 is from any facelift B5, avant, saloon, its all the same.
    Also, check out the Passat engine cover.
    There is a thread in the B5 section.
  22. ScottD3
    15,164
    1,123
    Alsie, post some interior pics up please mate. :D
  23. Alsie
    Alsie Member
    133
    I'd rather not.... It had a serious water leak, I closed the car up under a cover to keep the rain out, but opening it this week after 6 months and it's pretty nasty in there, hence why I'm now breaking....seats were plain cloth and pretty bring anyway, nothing special
    Alec Rose likes this.
  24. ScottD3
    15,164
    1,123
    Ahh fair point.
  25. Alsie
    Alsie Member
    133
    cheeky evening bump
  26. B5 BIKER
    B5 BIKER Member
    266
    Do you have the alarm siren for the boot.
    Take note, I'm in Ireland
  27. Alsie
    Alsie Member
    133
    yes i do, is ireland a problem?
  28. ScottD3
    15,164
    1,123
    It tends to be a bit more expensive.
  29. Alsie
    Alsie Member
    133
    oh ok.. will check with the post office.
  30. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    perhaps you can help me with a tiny part...
    inside the boot, on passanger side in corner nearest rear light is there a chromed eye for use with tie-straps?
    I have this eye but what I need is the little piece behind it that the eye screws into (bodyshop lost this for me!)
    let me know if that makes no sense or if it does and you have a price in mind?
    Thanks,
    P)
  31. B5 BIKER
    B5 BIKER Member
    266
    cheers, appreciate that.if its not too expensive i will sot it out for you friday morning
  32. aragorn
    18,578
    868
    What are the rear light clusters like? How much you wanting for them?
    PM Please :)
  33. Alsie
    Alsie Member
    133
    found it.. its a bracket £7 posted
  34. Alsie
    Alsie Member
    133
    will photograph them tomoz
  35. Alsie
    Alsie Member
    133
    which side is it on and any clues as to what it looks like?
  36. aragorn
    18,578
    868
    Depends on the exact age of car. Upto 97 they had a "dumb" siren in the left hand cubby (up and forward when you look in). Later cars had an electronic sounder, which was mounted in the right cubby, right down the bottom.
  37. B5 BIKER
    B5 BIKER Member
    266
    It's in the bottom right corner of the boot. You need to do a bit of rooting(nothing serious).
    Mine was a square black unit with a bracket attached to it for mounting to the car.
    It has a black wiring plug, plugged in to it
  38. aragorn
    18,578
    868
    If its the electronic type, you really want to make sure its working. They're usually dead by 10 years old due to the batteries leaking.
    I ended up getting one from a 2006 A8 or something to put in dawns.
  39. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,742
    165
    Rear ashtray (below armrest) does it work? is it grey? If so, how much?
    Dan
  40. Alsie
    Alsie Member
    133
    Yes alarm works, and will check ashtray tomoz and post pic
