Break light
mememe Oct 31, 2011
  1. mememe
    mememe Member
    107
    My passenger side break light only works when it wants to. The amber warning light comes on also. It spends most of the time not working and just decides to work for a bit then off again.
    Any ideas guys?
    Oh BTW, a beep has just started sounding when the light decides not to work. The beep never used to sound. Why would it start out of the blue?
  2. Digger1
    Digger1 Member
    439
    remove the light fitting and bulb clean the bulb housing replace bulb make sure the b-housing is a tight fit to the bulb check the loom is securely connected re-fit..
  3. mememe
    mememe Member
    107
    Thanks, done all of the above. I haven't yet checked for voltage at the plug but I will.
  4. quattrojames
    14,050
    578
    Is it the low pad light coming on? Orange?
    I'd check switch connections too.
