Break Leak
dublinS4 Apr 4, 2011
  1. dublinS4
    dublinS4 Member
    53
    Hi all.Ive got a leak coming from my driver side rear brake caliper. Does any body know where i can get my hands on a reconditioned one or a repair kit(seals)? I dont have the money to buy a brand new one from a dealer here in ireland(there robbing ba####ds over here!) Its a 98 s4 avant...
    Thanks for reading. Any help would be appriciated. Ps. Ive tried ebay and the one place that could have helped, have discontinued the above part.Here it is..
    eBay.ie: Audi S4 2.7 Avant Quattro 98-01 New Rear Brake Caliper (item 270622038907 end time 30-Mar-11 12:20:17 BST)
    Many thanks
    Stranded:(
  2. dublinS4
    dublinS4 Member
    53
    Oh, and a part number might be of help also
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    The repair kit is about £8 from Audi. I got a couple for facelift calipers a while back.
  4. dublinS4
    dublinS4 Member
    53
    Il give them a buzz in the morning. Do i need any special tools to fit the seals or would you recommend a specialist do it?
  5. Blue_Thunder
    1,771
    31
    Seals kit was actually £12 from Audi last year.
    No special tools other than a calliper wind back tool required. Think there is a good write up somewhere here - AudiWorld Tech Articles . Can't find it at the moment though as the web page doesn't allow my stupid phone to get the drop downs from the menu bar. Think you need to look under Resources.
  6. aragorn
    18,145
    765
    The prefacelift S4 calipers are the same as A4 quattros fwiw, opens up the scope a bit.
  7. dublinS4
    dublinS4 Member
    53
    Ordered a repair kit from my audi dealer. 23euros. Hope it works. Although im quite enjoying my bicycle at the moment. Il keep you posted
    cheers
    neil
  8. dublinS4
    dublinS4 Member
    53
    Dam kit is for the pistons only. My issue is with the seal around the hand brake mechanism.....
    The supplier said thats all that was listed... Any suggestions?
  9. aragorn
    18,145
    765
    bigg red do the seals for the handbrake mechanism, its pretty tricky to change that though, you need to mess around with circlips and big springs on the handbrake mechanism.
  10. dublinS4
    dublinS4 Member
    53
    New caliper from audi over here is 215yoyos. Think il ring audi in belfast and get a price in sterling...**** it, if its a bit chearer i might just buy it. Saves alot of hassle just swapping old to new...
  11. aragorn
    18,145
    765
    forget audi, find a local motor factors.
  12. dublinS4
    dublinS4 Member
    53
    As in calipers? Or the seal?
  13. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    You could try the Brake Supermarket.
    I've used them for bits and had no trouble.
    It would be a good idea to get the slider seals done at the same time - cost about £10-15.
  14. aragorn
    18,145
    765
    complete calipers.
    brake supermarket should do them, or find a local motorfactors.
  15. dublinS4
    dublinS4 Member
    53
    Priced them in belfast, 150euro all in, genuine audi units... 215euros in dublin. Sum difference eh?? Anyways, im gonna go and buy them up north... Many thanks lads...
  16. dublinS4
    dublinS4 Member
    53
    if i went to any motor factor over here.. id be told"main dealer only".. These guys arent helpfull over here... Bit behind you guys when it comes to cars and tunning..
