Brand new car, brand new VCDS cable. Advice please.
rich1 Aug 9, 2012
  1. rich1
    rich1 Member
    82
    Hi,
    I going to Audi on saturday to fit my RNS-e to my new car as i spec'd it without it for financial reasons.
    It's brand new and not even registered yet so want to make sure everything goes to plan..
    I obviously am fitting the RNS-e so would like a few tips on what i need to select/coding etc (in simple english would be perfect) and if there are any good little tweaks i can do to the car to make it a bit better, like making it beep when i lock it etc
    Car is a A3 2.0 Tdi sportback black edition if that helps.
    Rich
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Starter for 10: LINK
    Specialist support on here can be offered (Forum member: NHN), but Nige is out of UK at present.
  3. rich1
    rich1 Member
    82
    Ok thanks.
    Are their any cool little tweaks that can be done to the car?
  4. NHN
    29,331
    1,716
    All depends on whats attached to the car tbh mate, best thing is to get the car in hand & have a look around coding, but be careful, always do full autoscan on 1st usage to refer back to & make notes of what changes you made so if something isnt quite right you can refer back to it to correct.
  5. rich1
    rich1 Member
    82
    Well i will get the rns-e coded in and sort out the other bits and then wait until I pick the car up to start playing with it..
  6. rich1
    rich1 Member
    82
    All fitted etc but looking at the vcds it keeps coming up with no response from controller on certain modules?
  7. NHN
    29,331
    1,716
    You need to post a log up so we can see the issues 1st hand.
  8. rich1
    rich1 Member
    82
    Saturday,11,August,2012,10:49:15:51278
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 7N0
    Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 61 62 72
    77
    VIN: WAUZZZ8P5DA006585 Mileage: 20km/12miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes
    Cannot be reached
    Address 08: Auto HVAC
    Cannot be reached
    Address 09: Cent. Elect.
    Cannot be reached
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 983 G HW: 8P0 920 983 G
    Component: KOMBIINSTR. VDO H03 0360
    Revision: D0H03004 Serial number: 2245L004001600
    Coding: 0260428
    Shop #: WSC 00029 210 186132
    VCID: 3E750081696C949
    No fault code found.
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
    Component: J533 Gateway H43 1632
    Revision: H43 Serial number: 180512F1001459
    Coding: 352103
    Shop #: WSC 06314 000 00000
    VCID: 40897E79D398E29
    2 Faults Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 42
    Mileage: 22 km
    Time Indication: 0
    Date: 2012.08.11
    Time: 09:40:27
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 9
    Mileage: 22 km
    Time Indication: 0
    Date: 2012.08.11
    Time: 09:46:53
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H03004 Serial number: AUX7Z0L5FN50IZ
    Shop #: WSC 00000 000 00000
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7MD203313
    Coding: 0205700
    Shop #: WSC 00000 000 00001
    VCID: 346122A957204E9
    5 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 42
    Freeze Frame:
    Mileage: 20 km
    Count: 1108
    Clock: 10:34
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 2
    Mileage: 22 km
    Time Indication: 0
    Date: 2012.08.11
    Time: 10:18:22
    Freeze Frame:
    Mileage: 20 km
    Count: 1108
    Clock: 10:34
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 170
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 170
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 0
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist
    Cannot be reached
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 55: Xenon Range
    Cannot be reached
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205700
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 42
    Freeze Frame:
    Mileage: 20 km
    Count: 1108
    Clock: 10:34
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 2
    Mileage: 22 km
    Time Indication: 0
    Date: 2012.08.11
    Time: 10:18:22
    Freeze Frame:
    Mileage: 20 km
    Count: 1108
    Clock: 10:34
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 170
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 170
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 0
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 7N0 907 530 J
    Component: Batt.regelung H43 1632
    Coding: F30F185A
    VCID: F1EF6BBD28B2BB1
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005542566
    Coding: 0001222
    VCID: 35671FAD5C5A571
    1 Fault Found:
    02503 - Output Wire to Radio
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 42
    Mileage: 22 km
    Time Indication: 0
    Date: 2012.08.11
    Time: 09:40:32
    End ---------------------------------------------------------------------
    Address 56:8P0 035 193 G recoded (Short coding) from 0205700 to 0205704 (00000/000/00000)
    Address 10:8P0 919 475 M recoded (Long Coding) from 000003 to 100003 (06314/000/00000)
    Address 37:8P0 035 193 G recoded (Short coding) from 0205700 to 0205704 (00000/000/00000)
    Address 09:8P0 907 063 N recoded (Long Coding) from 4E000A2FA005F0C0207041E00100095C427E2BAA206DD12AE4008F840041 to 4E000A2FF037F0C0207041E00100095C427E2BAA206DD12AE4008F840041 (06314/000/00000)
    Address 77:8P1 862 335 A recoded (Short coding) from 0001222 to 0011422 (06314/000/00000)
  9. NHN
    29,331
    1,716
    Go into each module directly, not via a scan, that cant be reached except for 46 & see if it responds normally in there.
    Go into can gateway & choose installation list clickable & click the tick box for Navi 37 which should then show nav 37 as registered when doing a scan of modules.
